Old 01-06-2010, 08:45 PM   #1
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Trans Trigger
It is a device in which releases the trans-brake. Rather than a button and mashing it , you actually squeeze a trigger as if pulling a gun trigger. It looks kinda like a quarter stick pistol grip with the lever in front of it (like the part you squeeze to change a gear on the quarte-stick) it is spring loaded . When you want to release the trans-brake all you do is pull the lever while holding the pistol grip in the palm of your hand.Takes away flenching and other variables. Very trick peice. My son has wom numorous rounds with this thing.You also cannot accidently go back on trans-brake once you squeeze trigger, that is what mostly got it approved as for a safety feature on down track trans-brake mis-haps.
Old 01-07-2010, 04:36 PM   #2
PB Candies
Default Re: Trans Trigger
Is there a web site and or pictures to look at this devise?
PB Candies is offline   Reply With Quote
Old 01-07-2010, 07:04 PM   #3
danny waters sr
dragraceresults.com bracket talk forum and ask under general discussion.
Old 01-07-2010, 08:38 PM   #4
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Trans Trigger
Neat idea we have used it before(borrowed one)--- They aint cheap either about $450 !!!!
Not sure if NHRA accepts then either---Neat idea and once you get used to it DEADLY CONSISTENT---Comp 387
Old 01-07-2010, 10:47 PM   #5
danny waters sr
NHRA does accept them. We had it on Danny's dragster at Z-MAX the first race and got down to three cars.
Old 01-08-2010, 08:28 PM   #6
slo stock
The web site is shootthelite.com. It isn't $450.00. They cost about $250.00. Very trick. Will never use a button again.
slo stock is offline   Reply With Quote
Old 01-08-2010, 09:26 PM   #7
danny waters sr
Question Re: Trans Trigger
That is NOT the original transtrigger. Richard Charnock is the owner of the transtrigger. They don't even look close. If you are interested in one,you owe it to yourself to look at the "transtrigger". Difference from nite to day. Not to say this " stl" is not good ,just never heard of them before.
Old 01-09-2010, 01:30 AM   #8
The Joker
Here ya'll go. Theres been a couple for sale over on DRR.
The Joker is offline   Reply With Quote
