Old 12-21-2009, 05:12 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default TH350 Cooling Line Fittings
Does anyone out there know of a source of a fitting that will thread into a stock TH350 transmission case and get me to a -6AN male fitting? The case has an odd thread that I believe is a 1/2" BSPP thread. From the factory there were brass adapters in the ports to connect to the steel tubing with an inverted flare fitting which I am currently using to get me to -6AN hose but it takes too many connections (possible leak points) so I want to clean up the plumbing and install some quick disconnect fittings on the trans lines, but all the kits that are available that I have seen either have 1/4" or 1/8" npt threads which will not work in this application.
Thanks
Chad
Chad E532 is offline   Reply With Quote
