Old 12-18-2009, 03:33 PM   #1
Casey Miles
Liked 507 Times in 92 Posts
Talking Re: Index Change
WOW!! Now I can run all out and not worry about getting too far up the qualifing sheet. LOL!!!
Old 12-18-2009, 03:42 PM   #2
Charley Downing
Liked 633 Times in 88 Posts
Default Re: Index Change
What about class winners do they still need to run -.50 under to win class?
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 12-18-2009, 04:10 PM   #3
Bob Don
Bob Don's Avatar
Liked 902 Times in 192 Posts
I was thinking the same thing. With the lowered indexes, they should dump that rule.
Old 12-18-2009, 04:15 PM   #4
west coast
Liked 223 Times in 73 Posts
I was reading too much into it. Greg is right. Div. and opens only count if you go fast enough for instant hp. 1.25 under the new indexes.
west coast is offline   Reply With Quote
Old 12-18-2009, 04:33 PM   #5
art leong
The way I see it . The fast guys have another .15 to play with. And the people that could just barely run the index, might have trouble in bad air.
But when you think about it taking a second under to get in the program, in the past.
It really doesn't change much
Personally I like the change
Art Leong 2095 SS
Old 12-18-2009, 04:37 PM   #6
Greg Hill
Liked 279 Times in 68 Posts
Mickey, all the combinations like the 396's the LT1's the LS1's have high hp ratings while the newer combos will never get hit. I don't really have a problem with the new rules if the combinations are fairly factored. The way it is now is a joke. I can't even run fast enough in my car to get looked at now,and I've got a decent car.
Greg Hill 4171 STK
Old 12-18-2009, 11:12 PM   #7
Toby Lang
Liked 2 Times in 1 Post
Greg,
It says in the very first paragraph of the announcement that they consulted with the Sportsman Racer Advisory Council before coming up with this change. Are you still a member of the council and is this what you advised them to do?
If I remember correctly the indexes were raised 2 tenths in the early 90s to increase participation. With this latest change it looks like they must have too much participation now and are looking to reduce it.
-Toby
Old 12-18-2009, 11:43 PM   #8
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Good point Toby. Something else that a lot of racers may not remember from back then though is that there were a few classes that only received .15 due to the performance of the cars in the classes at the time. I know T/SA and V/SA and one other missed out on the other .05 from back then. Does it matter now,not one bit? It`s all irrellevent,NHRA doesn`t care,they`ll do what they feel they need to to screw the "hobby" class racer. In a way I`m happy they did it.
Lane Weber
Old 12-18-2009, 11:46 PM   #9
Stock 608
This is a huge blow to my program. I was about a -30 player before and ok with that. Now i will most likely not be able to even run the index. I don't have the money to make up the difference. So my car will not see much nhra action in 2010, just bracket racing. I may end up still going to pomona since i had planed on it, but thats about it. I understand why it was done, but its a hard deal for racers on a tight budget and who's cars are not fast enough anymore...
Stock 608 is offline   Reply With Quote
Old 12-19-2009, 12:04 AM   #10
JRyan
Liked 112 Times in 31 Posts
Let me start this by saying my verdict is still out if I'm for or against the index change. On one hand it benefits my superstocker as it allows me a little more breathing room and on the other hand it makes it a little tougher on my low budget stocker I've been putting together. So with that being said.
I love it whenever the AHFS gets discussed with altitude corrections and the lack of understanding most have with how the altitude correction actually works. By the way we've said for the last ten years the altitude correction factors are probably off about 10% because you can somewhat cheat the car into going faster by making changes to compensate. When we used to run at Denver alot we'd change camshafts, converter, rear gear, transmission, tires, and jetting to run fast. So everyone that thinks it's so easy to just go to the mountain and go fast I'd invite you to load up in July and give it a shot.
Someone mentioned 1.25 under at altitude is the same as sea level. This statement is absolutely false. I'll give you an example. Oahe Speedway in Pierre SD is 1700' above sea level in SS/NA I get .24 correction. So my index there is now a 12.39 with my old index being a 12.69. This year at the National Open I went an actual 11.238. Under the new system this would be 1.152 that would equate to a 10.998. However, this is not what it factors to. That run is actually an 11.023. This is how records get figured at altitude. At Denver you lose close to a .10 at this speed. So lets say next year I run an 11.14 and reset the record. This would be 1.25 under should I automatically get HP even though the record is only going to be 1.23 under? So is 1.25 under at altitude still 1.25 under at sea level? According to NHRA's policy for setting records NO!
Also you can't use corrected altitude to figure factoring either. 1500' at Atco and 1500' in Pierre SD as an example are two completely different things. At one place you might get that air and it's cool and dense and the other it may be a little warmer and drier. The car isn't going to run the same nor is it necessarily going to take the same tune to run at either place.
My .02
Rick Ryan
