Old 12-18-2009, 02:49 PM   #1
Chad Rhodes
Default Re: Index Change
Oh well (note sig change from AA/SA to A/SA), it effects everyone the same. Unless you can't run .3 under
Chad Rhodes 2113 I/SA
Old 12-18-2009, 02:56 PM   #2
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
can you post the link someone thanks
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
Old 12-18-2009, 03:09 PM   #3
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Here is the link:
http://www.nhra.net/content/sportsma...9436&zoneid=85
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 12-18-2009, 03:10 PM   #4
fredjohnston
Liked 55 Times in 14 Posts
The AHFS will impact very few combinations with the new indexs. The HP committees job just got alot easier.
The new Mustangs and Mopars will most likely never see an adjustment.
The proper way to adjust horsepower ratings is to take the average under the index runs of each car/engine combination and average them against each other.
Example: car/engine average for combination X = .95 under index
car/engine average for combination Y = .75 under index
The HP needs to be adjusted for up (raised) for combination X or lowered (decreased) for combination Y.
They aren't reinventing the wheel or performing brain surgery here.
fredjohnston is offline   Reply With Quote
Old 12-18-2009, 03:40 PM   #5
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Or they could've just moved the trigger up .15, which is primarily what they've done. It just won't LOOK like a -1.55 under run on paper next time. Now guys can race to 1,150'. Maybe they can put a cone out there for that. Congratulations, NHRA, you've accomplished.... um.... something, I guess.
Old 12-18-2009, 03:51 PM   #6
Casey Miles
Liked 508 Times in 92 Posts
Talking Re: Index Change
NHRA could have approached the indexes a different way. They could've just made a valve spring pressure rule that would slow everyone up. Make it so that the pressure can't exceed 150 lbs on the seat. But NHRA doesn't want to work for their membership money which means testing pressures of the valve springs.
Casey Miles
248H (Exceptionally/Slow)
Old 12-18-2009, 03:56 PM   #7
west coast
Liked 223 Times in 73 Posts
Now Div and Nat open count and alt adjust tracks this will put alot more runs in AHFS. Should of lower the triggers by .3 or more.
west coast is offline   Reply With Quote
Old 12-18-2009, 04:05 PM   #8
Greg Hill
Liked 279 Times in 68 Posts
Div. and opens only count if you go fast enough for instant hp. 1.25 under the new indexes.
Greg Hill 4171 STK
Old 12-18-2009, 04:15 PM   #9
Mickey Whaley
Thumbs down Re: Index Change
so basically the cars that haven't been hit with HP have a huge advantage
Mickey Whaley is offline   Reply With Quote
Old 12-18-2009, 04:58 PM   #10
hadtobethere
yup, the ones that bagged got their xmas gift
hadtobethere is offline   Reply With Quote
