Old 12-08-2009, 12:10 AM   #1
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Thumbs down Re: Hood Scoops to Comp
This one should be good. Only the guys with modified cars will be pi**ed off. Good luck with this.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 12-08-2009, 12:29 AM   #2
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: Hood Scoops to Comp
I guess Don doesn't have an agenda with this idea.If someone has the patience to list all the so called Pro Sportsman Racers I think you'll see quite a number run hood scoop cars. That means he has a better chance to go a round or two.Wadda ya say Don?
I don't have to deal with them so it's just an "opinion" on my part.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 12-08-2009, 12:32 AM   #3
Ed Carpenter
How about DeFrank and Fletcher to start.
Ed Carpenter
Old 12-08-2009, 12:34 AM   #4
Don Kennedy
Liked 902 Times in 237 Posts
Ed You crack me up you think anyone who has an new idea or starts a post has an agenda which is nothing wrong with that you just make me laugh
oh ed by the way I could care less about the touring pro sportsman fyi
Don Kennedy 7701 SS
Old 12-08-2009, 12:43 AM   #5
Ed Fernandez
Cool Re: Hood Scoops to Comp
Yeah I can see that.I'm glad I make you laugh.Good night Don.
Wanna make an offer on the mini diapers?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 12-08-2009, 01:12 AM   #6
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Not to hijack the thread,but I really need an explanation of Comp Eliminator.I really don't understand it anymore.
I was reading my last National Dragster and a comment was made about not wanting to take a permanent hit,even in the final,by running .66 or .67 under.
" I'm just not going to render this car useless" was the quote.
How does Comp work?
It doesn't sound like a very appealing class.Run too slow and you lose,but run too fast and your car is useless?
Old 12-08-2009, 01:33 AM   #7
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
How does Comp work?
Comp can be, at times, confusing. It's almost a combination of bracket racing and first to the stripe.
Two cars (except those in the same class) are handicapped off of their class index. First one to the stripe wins. But there is a catch, the Competition Index Control (CIC). Similar to the -1.40 under rule for S/SS racing. If a driver runs more than -.509 under their Index in eliminations, their Index is reduced one hundreth, for each hundreth they exceed the -.50, temporarily (for that race only, for that driver only). After a driver runs more than -.610 under their original Index, it becomes a permanent Class index adjustment, for everyone in that class. For example:
A driver is competing in C/Altered, with an Index of 8.00. In winning the first round, they run 7.460. Meaning their Index for round two is 7.96. Second round their opponent redlights, so they can lift and "save the Index". Round three, they win, and run 7.423, seconds, so their Index for the semifinals is 7.93. They win the semifinals, running 7.400. Their Index for the final will be 7.90. If they do not run any quicker than 7.391 in the final, the Index will return to 8.00 for everyone in C/A following the event. However, if that driver runs 7.350 in the final (regardless of a win or loss), the Index will be 7.95 for everyone in C/A in the country. The permanent Index hit chart is as follows:
-.61 under original Index = .01 permanent change
-.62 = .02
-.63 = .03
-.64 = .04
-.65.to -.699 = .05
-.710 = .06
-.72 = .07
-.73 = .08
-.74 = .09
-.750 and more = .10.
A tenth is the maximum penalty a driver/class can incur in one event. A driver that runs -.800 under in round one will lose three tenths for round two, but only one tenth permanently. So for round two, the Index will be 7.70 for yourself, and adjusted to 7.90 for everyone the following Monday
Now, back the temporary CIC deal. If you have accrued .07 temporary penalties in C/A (having run 7.928, adjusting the original Index down from 8.00 to 7.93) and another C/A racer has accumulated .02 (down to 7.98), if you race each other in eliminations, the Index goes back to 8.00 for you both, and it's heads-up. The winner will revert back to their adjusted Index (plus any penalty incurred in the Class run) for the next round. So, if you run 7.410 in your Class run, your Index goes from the previous 7.93 to 7.91 for the next round. So, you need to get their first, but attempt to do so by the slimmest of margine, to minimize any Index penalties. If a racer causes a permanent Index adjustment in two different classes, he/she is relegated to those two classes for the remainder of the season.
Hope this helps. How'd I do, Professor Ring?
Old 12-08-2009, 12:09 PM   #8
Bobby DiDomenico
Liked 101 Times in 52 Posts
Wink Re: Hood Scoops to Comp
How does Comp work?
Wait, isn't that Stock Eliminator?
(Just missing something called "the possible heads up run" correct?)
