Liked 6 Times in 5 Posts
We use BES RACING ENGINE two, and Rich the tuner is great,and they make LOTS OF HORSEPOWER!!
Liked 165 Times in 59 Posts
i didnt dyno test my combo,(i should of ),i depends on your combo (is it brand new ,,carb,,cam ,,heads)or is it a combo with mild changes that depends on dyno time or not ,you cant race a dyno ,,but it is a great tool for start up and unforseen issues such as leaks,afr,exhaust temp,oil presure at high rpm,and geting a base line to start from ,but dont be disappointed in the numbers that come off the dyno ,every one of those units is not consitant with hp/torque numbers ,like mentioned work with your machine shop ,,pitch in to do work in hook up and have an arsonal of items to try once the base line is set
easy items (different size headers,couple carbs,even rocker arm sets ,) gmonde |
Liked 564 Times in 66 Posts
When you have decided to dyno engines as part of your program, always use the same dyno and operator. This way when there is a change in HP you will know when to be pleased or concerned.
Bill |
