Old 11-25-2009, 03:26 PM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: dyno testing
Originally Posted by Ed OBrien View Post
You need an operator that is a good tuner and some are better than others . Have a nice day
Rick, Ed is right. I have used Mike Keown and BES. Also, both are very knowledgible, excellent tuners and trustworthy. Classy gentleman and truly care about taking care of your stuff.
Mike Keown 812 282 4726
BES Racing 812 576 2371
You wont be disappointed.....
Wade Owens
Old 11-25-2009, 07:19 PM   #2
TinSoldier 3215
Liked 6 Times in 5 Posts
We use BES RACING ENGINE two, and Rich the tuner is great,and they make LOTS OF HORSEPOWER!! great guys!!!
TinSoldier 3215 is offline   Reply With Quote
Old 11-25-2009, 08:26 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i didnt dyno test my combo,(i should of ),i depends on your combo (is it brand new ,,carb,,cam ,,heads)or is it a combo with mild changes that depends on dyno time or not ,you cant race a dyno ,,but it is a great tool for start up and unforseen issues such as leaks,afr,exhaust temp,oil presure at high rpm,and geting a base line to start from ,but dont be disappointed in the numbers that come off the dyno ,every one of those units is not consitant with hp/torque numbers ,like mentioned work with your machine shop ,,pitch in to do work in hook up and have an arsonal of items to try once the base line is set
easy items (different size headers,couple carbs,even rocker arm sets ,)
gmonde
Old 11-26-2009, 09:51 AM   #4
Bill Grubbs
Liked 564 Times in 66 Posts
When you have decided to dyno engines as part of your program, always use the same dyno and operator. This way when there is a change in HP you will know when to be pleased or concerned.
Bill
Bill Grubbs is offline   Reply With Quote
