Old 11-09-2009, 12:54 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: ford clutch help
Terry, I have a on ocassion had to "reverse" bleed some systems.Take the slave cyl. loose allow the piston to extend then slowly push the piston in and release and repeat. The air if you have any has an easier time going up into the M.C. Just leave the cap off of M.C. until your'e done bleeding . Joe
Joe Buchanan SS/BX 3117
