Liked 99 Times in 60 Posts
John,
I have been thinking about you brakes, the factory ft disc system "should" do a good job. Those 75 Nova fr discs are the same as all G body systems, a solid, proven system. Maybe the rear brakes are where your upgrade money needs to go. Also, double check the basics, pedal ratio? line pressure at the caliper? which master are run using? condition of the rear brakes? AnyWho, give the complete brake system a check over and some thought. Consider talking with some brake manufacturers about your needs. Larry
Larry Woodfin 471W |
