Old 10-16-2009, 09:11 AM   #1
Brian VP
Liked 8 Times in 1 Post
Default Re: Drag pak Challenger
I kind of thought the same thing. I thought that you had to use the stock suspension mounts and bolt on traction devices.
Brian Van Poppel 1682 SS
Brian VP is offline   Reply With Quote
Old 10-16-2009, 09:16 AM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Drag pak Challenger
Welcome to the "REAL" world of special limited production stockers and you guys bitch about crate engined stockers.
Old 10-16-2009, 09:19 AM   #3
BlueOval Ralph
Banned
It has know become what ever is put on the crate cars is legal!!!! T-Bolt have weld on traction bars and they are legal for Stock
QUOTE=X-TECH MAN;146356]Welcome to the "REAL" world of special limited production stockers and you guys bitch about crate engined stockers.[/QUOTE]
BlueOval Ralph is offline   Reply With Quote
Old 10-16-2009, 09:21 AM   #4
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
X Tech Guy
Why would this be considered a Real world of special limited Cars? Did these cars get the ok from NHRA
to Mount the rearend the way its shown? They are allowing these cars to run what looks to me as a modified
four link set up ? enlighten us please
BTW Im not taking anything away from the owner or the builder of this car Very nice job, Im just curious to know a
a little more on these new Hot Rods
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 10-16-2009, 10:12 AM   #5
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
NHRA did not allow the vettes to mount a 12 bolt like that, it was shot down long ago. Now it looks like anything goes.
Bob Pagano A/SA
Old 10-16-2009, 10:54 AM   #6
TommyTucker
I've just talked to Andre about your concerns. This is a stock drag pak elminatorr with an NHRA approved rear suspension, apparently because these cars have stock independant suspension. Thanks for the replies and I will try to answer anything I can.
Tom
TommyTucker is offline   Reply With Quote
Old 10-16-2009, 12:15 PM   #7
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Tom
That is correct, its all NHRA Ok'd....The cars ship with the rear set up shown (these are at MPR in Michigan and came out of a couple of cars they have completed)
They are Jeep units, the NHRA allows the upper arms to be adjustable on the 4 link setup and a panhard to be run.
I can/will post scans of my "manual" for that section that came with our car (#24) being built by Mike at MPR right now.
Yep its legal
We are however unlike almost(except 2 I know of) going to run an 8 3/4 rear , Moser makes an aftermarket housing thats thiker/stronger , its actually based on a ford 9 inch unit with 8 3/4 flange and round back. That too is NHRA approved for use in the car. I would have gone with a dana because of gear selection, but now that Richmond is making an 4.86 Pro gear I decided to opt for the weight savings.
I have pics of just about everything in great detail of our car as it came, more to follow, if there is something specific anyone is looking for let me know and Ill send you a link.
Cheers
Chris
Chris "drooze" Wertman is offline   Reply With Quote
Old 10-16-2009, 12:28 PM   #8
Bob Pagano
Bob Pagano's Avatar
Tom I did not infer that it was not legal only that the independent rear suspensions changed to 12bolt on Corvettes can not be adjustable. That is what kills an L-88 push to hard and your on the bumper.
Bob Pagano A/SA
Old 10-25-2009, 05:57 AM   #9
GUMP
Liked 2,354 Times in 554 Posts
The biggest problem with these cars is that the stock control arms swing in the wrong direction. The factory supplied this design. I can't see where its any better than what's under an earlier Corvette.
Take Care,
Daren
GUMP is online now   Reply With Quote
Old 11-04-2009, 07:40 PM   #10
DonatoEng
Liked 8 Times in 5 Posts
NHRA requires that the stock shock and spring mounts on the body must be used for an independent suspension conversion to solid axle in Stock. The Challenger uses these with specific locations for the upper and lower control arm mounting holes on the body and axle ends. The rear suspension layout is based on a production Chrysler vehicle
The Corvette has the odd spring setup to meet these requirements.
DonatoEng is offline   Reply With Quote
