Old 10-09-2009, 11:59 AM   #1
Chad Rhodes
Default Re: AHFS and the CJs
Originally Posted by A/SA Fairlane View Post
You have it right Bill but the 9.83 (1.42 under) today by the stick car in Virginia should get atleast the stick guys 14hp
I don't see any distinction between the stick and auto combos as far as AHFS goes, they should both get hit
Chad Rhodes 2113 I/SA
Old 10-09-2009, 12:59 PM   #2
John Kelley
Originally Posted by chad rhodes View Post
i don't see any distinction between the stick and auto combos as far as ahfs goes, they should both get hit
NHRA does :-)
John Kelley is offline   Reply With Quote
Old 10-09-2009, 01:11 PM   #3
Evan Smith
Liked 115 Times in 5 Posts
Chad, that is a brilliant idea, why didn't you come up with it after the 396 got hit?
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 10-09-2009, 01:16 PM   #4
Chad Rhodes
Originally Posted by John Kelley View Post
NHRA does :-)
actually if you look at the class guide, there is no distinction between the stick combo and the auto combo, therefore both SHOULD get the HP. if the factor drops below 7.5 does that make them ineligible? serious question as I'm not sure
Old 10-09-2009, 04:14 PM   #5
Just Observing
Below a 7.5 pw factor would make them a AA/stock only combo. No matter how low a pw factor is you can run AA/stock.
Just Observing is offline   Reply With Quote
Old 10-09-2009, 04:23 PM   #6
junior barns
Liked 20 Times in 14 Posts
how close are these cars to being put in AA only??
junior barns is offline   Reply With Quote
Old 10-09-2009, 04:35 PM   #7
Dusty Lowell
Dusty Lowell's Avatar
Send a message via AIM to Dusty Lowell
8hp more will put the CJ Coupe under 7.5 factor
Dusty Lowell
#1773 STK F/SA
Dusty Lowell is offline   Reply With Quote
Old 10-09-2009, 04:43 PM   #8
Just Observing
Yes a 439 hp factor puts the coupe at 7.38, but the convertible will be at 7.57 pw factor and still would be able to fit A/stock.
Old 10-09-2009, 06:56 PM   #9
Sean Cour
Sean Cour's Avatar
Liked 125 Times in 40 Posts
Junior-
I believe it's four h.p., then they will be AA only.
Sean Cour is offline   Reply With Quote
Old 10-09-2009, 09:54 PM   #10
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Sean, is yours going to be an aa car?
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
