#41 |
Ed and Phil, you guys need to learn how to use the QUOTE function.
You got me there little fella |
#42 |
Check your PM's, bud.
2002 Division 6 High School Champion 2007 Division 6 Pro Champion 2007 Division 6 National Open Series Stock/Super Stock Champion |
#43 |
Banned
Liked 235 Times in 110 Posts
Going back to using class winners ONLY and inspect each one in teardown (let the GOOD tech guys do their jobs) for the eliminator would cure all this BS of shutting off at 1000 ft. It would also make the AHFS system work like it should especially if the trigger was brought down to .8 under. Get rid of that farthest under qualifyer and a lot of the bogus and high dollar stuff will start to go away. Thats the way it was done for years until the slow guys whined. If you didnt win class you got to watch on Sunday.
#44 |
Liked 22 Times in 22 Posts
it does not matter if they raise the index 2 seconds or lower it 5 seconds, it is still just a bracket race. and if you run someone in your exact class, and run 3 seconds under or 5 seconds over the car with the power wins. i love superstock, but it has lost the mystique. we have no real fan base like they had in the 70s.
don,t have one |
#45 |
Liked 584 Times in 94 Posts
Gump, I don't have a problem with any of the new cars. As long as the car can be purchased at the dealer, titled, and legally driven home. Then and only then should the car be eligible to be factored and compete as a Stocker. Stevie Wonder can tell the difference between a Drag Pac Challenger and a Showroom Challenger, or a New Showroom Mustang and a New Cobra Jet. I'm talking about "Purpose Built Factory Racecars". They are Superstockers.. period.. end. If you're gonna let them in stock, give them their own class or limit them to AA. I'll take my lumps (already have) and hope that the AHFS works, but wait for the whinning when the New Challenger starts showing up with the other "approved" engine combos and it infiltrates the lower classes....JB
#46 |
Liked 16 Times in 11 Posts
Jim is right on they are SS cars. The drag pak cars have the rear moved up 1/2 inch just like the showroom cars,,,,,,NOT, so they must be SS not to mention the intakes and alum oil pans OH I said not to mention that. Stock my a..
Bob Pagano A/SA |
#47 |
Liked 508 Times in 92 Posts
I know a way to factor all the cars, make them use the stock valve spring pressures and you'll see them all slow down. No need to refactor anyone engine, it'll be done on it's own.
Casey Miles 248H |
#48 | |
Liked 13 Times in 9 Posts
Consider: - Min & Max weights - combined classes (1.0 weight breaks, sticks & autos, or both) Results in: - cars no longer running 200lbs heavy - more heads-up runs - cars will quickly factor themselves to realistic numbers - guys can still get started in Stock relatively easily with the "soft" indexes, but are incentivized to make their cars faster. In all fairness, again, I'm not campaigning for these things... just academic discussion. Doesn't bother me either way if they adopt these things or not. It *would* bother me if they dropped all the indexes .50, as it effectively legislates cars out that are not hurting anything (In fact, quite the opposite... easy pickin's, right?) ![]()
#49 |
Liked 7,863 Times in 1,750 Posts
Michael, as a point in fact, some of the racers that were in "teardown" this past weekend at Z-Max were asked how much ballast they were carrying and where it was located. They were then given a good looking over. Fact finding mission?
#50 |
Liked 32 Times in 19 Posts
One year of No Break out Eliminations at National Events would Make for fast correction of HP factors when combined with a 1.00 under Monday Trigger. THIS WOULD FIX THE WEAK HP CARS>
PAY BIGGER money for eliminator to make it worth the work to run and win also. Last edited by Dick Butler; 09-23-2009 at 11:11 AM. |
