Old 09-10-2009, 09:33 PM   #1
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Rules for staging?
Originally Posted by Michael Pliska View Post
I've heard the same thing, that they have worked it out to where they can slam the brakes and use the "windup" in the slicks to bounce them backwards just after turning on the stage light. I wonder if the autostart system looks for a steady stage light or if it is tripped by a quick flicker like that?
Not sure about NHRA. IHRA in the Rulebook lists a "Staged Minimum", which I believe is the time a car must be fully staged to trigger the Autostart. It also lists "Staged to Start", I think is the time from when both cars are staged til the Tree activates. Stock and S/S (actually all Sportsman classes from T/D to H/R) have a 0.6 seconds "Staged Mnimum" listed. "Stage to Start" is 0.9 seconds for S/SS.
Old 09-11-2009, 08:28 AM   #2
Bimbo Jones
I believe the problem was fixed a couple of seasons back but some tracks may not have installed the software upgrade to correct it. I was just fishing to see how many were aware of it and if any of you were ever victims of this issue. I believe the bug was fixed by reprograming the count down to only take place while the third bulb is activated and if a driver backs out of the stage beam the count down will stop counting down and will restart at the beginning when the third light is turned on again. Anyway I am amased that someone would even be able to discover such a bazar scenario and even more difficult to imagine someone being able to us it as a driving technique to catch a opponent off guard for a starting line advantage.
Bimbo Jones is offline   Reply With Quote
Old 09-18-2009, 06:25 PM   #3
Raceready
Question Re: Rules for staging?
Mike Carr is correct.At least that is the way it works with a compulink system.I don't know about TSI or any of the other systems.IMHO compulink is the only system.If you are racing at a track without it you will get screwed sometime,somehow.And I have to add this Question,it is not directed at any one person.How can you understand the rules and regulations of stock or super stock and not understand how the tree works??
Raceready is offline   Reply With Quote
Old 09-18-2009, 10:25 PM   #4
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
Not touchin that question with a 10 ft pool. Or a 50 ft .........
2002 Division 6 High School Champion
2007 Division 6 Pro Champion
2007 Division 6 National Open Series Stock/Super Stock Champion
Sean Kennedy is offline   Reply With Quote
Old 09-19-2009, 08:59 AM   #5
art leong
My original question had nothing to do with how the tree works. It was about starting proceedures. It was about what I thought was courtesy staging. One bulb at a time. Many racers I talked to did not realize you could roll in and light 2 bulbs. After the other lane lights the first. Now I know
PARDON MY STUPIDITY
Art Leong 2095 SS
