Old 09-04-2009, 05:24 PM   #1
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
Default Re: CJ OUT at Indy!!
Originally Posted by clutch man View Post
How do you know this, do you sit with them every day???????????????? Keep dreaming ford lover!
I do know a lil info on these cars. how about posting a real name......instead of hiding internet racer!!!!!!!!!!!!!!!!!!!!!!
Stephen & Horace Johnson is offline   Reply With Quote
Old 09-04-2009, 05:40 PM   #2
davidhuff
Liked 120 Times in 42 Posts
Well who won a/sa?
Old 09-04-2009, 05:47 PM   #3
Originally Posted by davidhuff View Post
Well who won a/sa?
very good question David.
Stephen Johnson #2162
Horace Johnson #2162
Old 09-04-2009, 05:57 PM   #4
Andrew Hill
Andrew Hill's Avatar
Liked 173 Times in 39 Posts
The CJ that won A/SA was not one of the ones tossed, so he won.
Andrew Hill is offline   Reply With Quote
Old 09-04-2009, 05:57 PM   #5
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
If I read correctly Jimmy Holzman got tossed. Chad Holzman didn't.
Floyd Staggs 787 SST
Old 09-04-2009, 05:59 PM   #6
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Question Re: CJ OUT at Indy!!
If they tossed a couple CJ cars,then how can the other ones be fine?Aren't they all the same except for weight and transmission type?
Sorry,this question has already been asked.
And it sure does seem silly to worry about what kind of pistons a car has when it has a supercharger on it.
Old 09-04-2009, 07:16 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
In the old days.....ALL class winners got torn down and if they were found illegal the r/up got torn down...and if they were found illegal......there was no class winner! Been there and done that as the saying goes....If a car is not torn down it's obvioulsy considered legal......
Rich Biebel
S/C 1479
Stock 147R
Old 09-04-2009, 10:04 PM   #8
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Al - good point. We got tossed at the KC National Open last fall b/c after we reset our GTE record, two combustion chambers measured incorrect. One by a meer .4 of a cc also. Sent the heads back to Dave Layer and he said they checked fine. The short of it...we have heads that make us SHORT on power just so they will pass NHRA inspection. It DOES matter what equipment is used.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 09-04-2009, 10:05 PM   #9
Jeremy
I posted on this burette problem earlier this year and it didn't get much attention.
I checked two of NHRA's burette's against mine and all three were different. NHRA's high dollar/quality burette's had a differents of point eight cc's on a 100 cc's which is alot when your checking 150-200 cc port volume.
I googled on the internet and it says class A burette's (best) only have to be within one cc to be with in spec's.
Thanks
Jerry
Jeremy is offline   Reply With Quote
Old 09-05-2009, 07:40 PM   #10
OLD INJUN
442OLDS
You have a pm.
OLD INJUN is offline   Reply With Quote
