Old 08-16-2009, 12:20 PM   #2
Cisco Kid
Cisco Kid's Avatar
Send a message via AIM to Cisco Kid
Default Re: BBC Distributor Set Up??
remove all plugs,and distributor....
bring #1 (fwd most plug on drivers side) to top dead center,line up oil pump shaft with bottom of distributor (eye ball it! you will have to mess with it a little bit till you get it right)...drop in distributor with rotor button facing #1 cylinder,install all wires and plugs and shaaazzaaam get yourself a timing light and set the timing...thats just the way i was taught how to do it!
firing
Cisco Kid is offline   Reply With Quote
