Old 08-15-2009, 02:22 PM   #1
Bench Racer
Liked 99 Times in 21 Posts
Default Re: Who Sells the Adjustable Brake Pressure Launch Control Switches??
While on the subject, you used to see a lot of brake line pressure gauges in use. Normally how much pressure is required to lock the front brakes during a burn out, or staging the car? I know you see a lot of guys pumping the brake pedal as hard and quick as a Nascar jackman lifting the car for a tire change. Don Jackson
Bench Racer is offline   Reply With Quote
