Old 07-16-2009, 02:34 PM   #13
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: The gremlins have taken over my car
Double check your ground connections. They are extrememly important when using an MSD. The ground wire from the box should go directly to the engine block. Be sure you have a ground strap running from the block to the chassis as well. Good luck.
Jim Kaekel 3836 STK
