Jeff and David: Regarding the 3-bbl carb and intake, Chrysler completed the design modifications to the carb and 'short track' manifold and submitted them to NASCAR one week before the Firecracker 400 at Daytona in 1964. The combination was accepted by them and ran at that race. The manifold was the '043' magnesium version with the rear half of the plenum modified to accept the wide 3-bbl throttle blade. Les Norton runs this manifold on his car as it has been accepted by NHRA even though the carb has not been accepted! The interesting part of the story is that the Chrysler engineers spent a lot of time and money trying to get the 3-bbl to work, and even had to move the secondary boosters to correct the fuel distribution. Eventually they said it was worth 2% HP improvement, the same as they found in early testing with Hilborn fuel injection. The carb is a Holley model 3085A P/N 2536406 and used base plate gasket 2536411. One of these would be a rare find as it is not the same as the generic 3-bbl Holleys that were later sold over the counter. Anyway, it's not legal in stock, just an interesting story. By the way, I came about this information when a good friend let me look over an extensive collection of weekly engineering meeting minutes from late '63 to mid '64 by the group developing the A 864 engine program which included both the NASCAR engine and the Drag Race cross ram engine. Facinating reading. These guys were so far ahead of everyone else it was scary. Hollow stem valves, titanium retainers, a slew of light weight proposals including gun drilled cams, titanium wrist pins, Hilborns without conventional throttle blades. What we got was aluminum heads, oil and water pumps, mag intakes and more.
#2 | |
Banned
Liked 235 Times in 110 Posts
Liked 16 Times in 11 Posts
Item number: 250447430693 ebay Nascar carb, no intakes at this time but have seen a few in the last couple years even the wedge nascar intake, there were two just last month.
Bob Pagano A/SA |
Sponsor
Thanks for the interesting facts Steve.
The intake I have here at the shop is the exact same one you're talking about. Which intake did they have before they had the 3 bbl approved? Was it the same one without the 3 bbl modification? |
Liked 138 Times in 51 Posts
Is this one of the Hemi Nascar single carb intakes being talked about, or a similar version with that has the carb "sunk" in the top half?
http://wwnboa.com/jpgs/wwnboamckinney2.jpg ....and I also found this! http://www.thehemi.com/gallery.php?id=0003
LOCOMOTION Racing Last edited by Myron Piatek; 06-22-2009 at 07:46 PM. |
Liked 10,731 Times in 2,233 Posts
Dave I run a steel shaker with factory, "lead" trim ring and scoop inserts. I think this hood looks much cooler than the AAR hood. The air cleaner top is OEM steel and the intake is a real piece with the correct casting number the carbs are corect for a '71 six pac. Drop by at Norwalk and check it out for yourself.
A/SA now has 15 cars that will be four rounds of fun for two people. Last edited by Larry Hill; 06-22-2009 at 08:28 PM. |
Sponsor
I think it would be great to run A/SA with so many cars but I don't want to get hit with HP. And how many cars lose class on purpose just to protect their combo? What kind of racing is that? At least in AA you can run balls out. At least for now anyway.
#8 | |
David; The '043' intakes for the 4-BBL carb had a notch cut in the divider wall that ran between the centerlines of the primary and secondary throttle shafts and was about .68" deep. I asked Gendora if the M-1 intake could be cut to match the '043' and unfortunately the answer was no. Steve
