Old 06-21-2009, 02:44 AM   #1
Darrin Christen
Darrin Christen's Avatar
Default Re: Steering Gear adj/Front end alignment
Ed, There is an adjustment on the top of the steering box. Loosen the jam nut and turn the adjustment screw clockwise and you should be able to take some of the slack out. I ended up having to replace the gear box on mine several years back. As for the alignment problem I would call Eddie. Doesn't he supply some new alignment procedure when installing his kit? BTW nice meeting you and your son in Houston.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
