Old 06-06-2009, 10:35 PM   #31
Pat Cook
Default Re: PCV, advantage or not?
So Bub, theoretically speaking, so as not to give any thing away. If the engine is sealed up good and tight, a brake booster check valve could be used in one of the valve covers, a length of sizable hose could be used to connect the booster check valve to the carb, say at the original connection for the PCV connection.
Then lets say this theoretical system could be used to pull a vacuum in the engine and aid in ring seal? say after the car turns on the first amber in the staging process, the driver puts the car in neutral and wings the engine a few times......say kinda like pulling a really good vacuum on a "large can" this vacuum would last long enough to get the car to the other end of the track before crank case pressure exceeded the vacuum,
All in theory of course.....
Pat Cook is offline   Reply With Quote
Old 06-07-2009, 12:08 PM   #32
Bub Whitaker
DING DING DING... we have a winner
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 06-08-2009, 08:19 PM   #33
Tand E racing
This is a little off the PCV valve topic, am curious if any one here has tried attaching a PCV valve or e-vac system to the area where the stock fuel pump would go? (chebbie of course) seems like a great place to evacuate from.
Tand E racing is offline   Reply With Quote
Old 06-08-2009, 08:33 PM   #34
Bub Whitaker
The crank spinning clockwise is throwing oil at that area, the passage to the cam for the fuel pump pushrod is also filling that area, so no...all you will evacuate is oil...even trying to read vacumn from there will give you false readings from all the oil that accumulates
Bub Whitaker
Old 06-09-2009, 12:27 AM   #35
Jeff Lee
Jeff Lee's Avatar
Well Bub, your half-way there! OK, maybe 3/4 there...
Jeff Lee 7494 D/S '70 AMX
Old 06-09-2009, 01:39 AM   #36
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
There is one particular Super Stocker that I can think of that has it and he is wicked fast. There has to be a reason to do it.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-09-2009, 10:50 AM   #37
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
this all sounds good except the "...and wings the engine a few times..". i thought the PVC port creates the most vacuum at idle? wouldn't you be better to do the burn out, give the carb a few wacks if thats what your into, then pre stage and stage as close to idle as you can to create maximum vacuum
Ian
Ian Hill is offline   Reply With Quote
Old 06-09-2009, 11:26 AM   #38
Buicksstage1
Buicksstage1's Avatar
Originally Posted by junior barns View Post
what does PCV stand for?
Positive Crankcase Ventilation.......Chris
72GS stage2 455 street/strip best et 9.93
1970 Stage1 iron heads,stock rods. 1.37 60' 10.17@129.8
70 GSX clone, 9.3:1 455 stage2 best et 11.00
Buicksstage1 is offline   Reply With Quote
Old 06-09-2009, 07:33 PM   #39
Bub Whitaker
Thanks Jeff, but I'm all the way there... At my age, I'm just backin off a little for you guys..
and Ian Hill, part throttle builds the most vacume
Bub Whitaker
Old 06-09-2009, 11:10 PM   #40
Pat Cook
and a PCV valve does not hold a vacuum as well as a brake booster check valve.
67 Ford Fairlane
F/SA
749
