Old 05-30-2009, 01:47 PM   #1
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Motor Home Towing
the thing that will help that unit is a trans cooler ,it may have a factory one on it but, put the biggest one you can fit on it and by pass the radiator you don t need the engine temp to build any heat,unless you towing in sub zero temps you dont need it,you should be ok,amd like mentioned trans temp gauge is key gmonde
Old 05-30-2009, 07:53 PM   #2
T Hall
T Hall's Avatar
My dad has one that he pulls a 28 ft trailer with. Has been fo about 6 years, Never a problem. The triton v10 lacks on power, so he added the Banks system, and it made a HUGE difference, as far as tranny, no probs.
Tony Hall
3545 S/ST
T Hall is offline   Reply With Quote
