Old 05-07-2009, 03:00 PM   #16
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Default Re: No HP on the Sorenson combo?
I agree with you Jim, but if it is a run of 1.40 or more under and it will affect your HP rating then it should be mandatory to weigh and tear down regardless of whether you win or lose. (although not in the rule book) I think this whole thread has gotten off the topic of what really happened. I don't care if it was windy, I don't care if the scales were fluctuating, I don't care if your weather station said you were going to slow down, if you ran 1.391 under why would you take the chance of possibly going faster. I was not there but if water was indeed drained from the raditor or anyother item was removed from the car that was in the car during the run should have remained in the car when scaled (including the water). So tell me, does this set a rule of thumb for anyone that goes 1.40 under, take what you can out of the car (drain the water, drain the oil, drain the trans fluid, leave your jacket, helmet and pants with the car behind you) so that you are light and the run doesn't count? I would like to see someone get that by Bruce or Travis here in D3 ...
That is the biggest problem I have with NHRA is the inconsistancy across divisions.
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
