Old 04-28-2009, 06:50 PM   #5
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Chassis Tuning Help:
you will need to adjust the ladder bar . you can wind the spring up all you want and it's not gonna change much . ladder bars don't allow the rear roll like a 4-link would. i would check to see if there is preload on the bar now . just loosen the front bolt on the pass side and with your weight in the car see if it moves freely. i'll bet it out of adjustment and is holding that side down.
Mark Markow is offline   Reply With Quote
