I have a friend that would foot brake his 421 sbc and blew his 1.82 out. My trans guy says about stock planetarys "its not if but when" I have twisted the input shaft twice on my 1.76 now have turbo spline and coan super set problem solved.I did run a stout 496 bb with a glide and stock 1.76 wuth a brake for 2 years before I pulled the trigger on the super set and 1.76 never broke I guess I was just lucky.
Same trans different question, left off brake and car just sat there, went on stop with 4500 coast speed car starts moving when stop goes off the car takes off still in 1st gear. From then seems to work ok. Would like input..................Thanks
Liked 882 Times in 236 Posts
Bob , Bypass the brake output side of your delay box and power the brake solenoid to see if it applies and releases the brake properly. ...It could be a brake circuit relay sticking in the delay box , quite a few use electro-mechanical relays... ..it sounds as if the timer circuits are functioning correctly .....If it does it while bypassing the box,check the brake solenoid or the brake spool valve for sticking. .......Tom
Tom, can't do anything now as the trans is at the shop. I did tell him to put a new solenoid on it after it's freshened up..........but I'll ck the box when it's back together.........Thanks
Sorry didn't mean to steal the thread........ Last edited by Bob Verwold; 04-29-2009 at 06:57 AM. |
