Old 04-05-2009, 05:31 PM   #1
taylor51
Default Brand new 582 sunset brodix headhunter engine for sale
582 SUNSET BBC HEADHUNTER
I have a 100% brand new sunset/sputs 582 bbc conventional head engine for sale, this IS the hot combo for 2009, this is the same combo that has won the last two s/c world championships!!!! low maintence and big hp/torque. it would be perfect for high mph s/c or s/g or run it with a small shot of nos in t/d or t/s, will handle a 250 shot easily. it features the following items:
dart big m block with bronze lifter sleeves/bores and set up for the larger .903 lifters, billet caps
callies magnum plus 4.375 stroke.....this is the new style with the extra profiling
diamond 15 to 1 pistons with domes profiled by rebco, gas ported
manley steel rods, arp 2000 cap screws, 6.535 long
clevite h-series bearings
total seal file fit rings
moroso 21047 steel stroker pan
moroso 21063 billet oil pump and shaft
ati balancer and timing pointer
brodix head hunter BP HH BB 377 3xtra oval port conventional heads, fully cnc ported, manley nextek springs good for .900 lift, ***. retainers, 2.375 int/1.850 ext stainless valves, 465 cfm int/308 cfm exh flow
t&d pro series shaft rockers....1.80 int./1.75 exh.
manton pro series push rods, .120 wall
xts pro series belt drive
brodix head hunter intake ported and powdercoated "hammertone"
apd 1250 cfm gas carb custom built by john kyle at apd.
custom 7/4 swap comp cams roller cam
crower severe duty hippo option .903 lifters
williams bros. billet rail powdercoated "sparkle silver" valve covers with #12 moroso vent vac. fitting
fel pro mls head gaskets, rubber line/steel core valve cover and pan gaskets
all arp studs, bolts, ect.
sunset vac pump mount
All engine parts and combo design were done by tracy dennis at sunset racecraft, assembly and machine work was done by jami stoen at sputs racing engines. All parts are 100% brand new. Exact duplicate engines to this combo have been making 1075 to 1100 hp on sunsets dyno, this engine has not been dynoed yet. has never been started. build was finished on 03/28/09
There are a bunch of upgrades on this engine over what the big engine builders are selling normally, new style magnum crank, .903 lifters and lifter bore sleeves, dome profiling, powdercoated parts, headhunter heads and intake, ect. are all add on's over what is the normal from the big builders.
Note: this engine does not come with plug wires, distributor, or vac. pump. What is listed above is what is included.
I have over $21,000 into this, will sell for much less. sold dragster and no longer need. shipping is not included in asking price. engine is in crate and ready to ship.
ASKING PRICE IS $18,000 OBO, MAKE OFFERS, MUST SELL.
thanks,
mike taylor
641-423-7165 home
641-425-0391 cell
641-424-6111 work
mgt16@mchsi.com
taylor51 is offline   Reply With Quote
Search this Thread:
Advanced Search
