They do not run class often enough to talk about. And when they do, if there is inclement weather, the first thing to get canceled is class eliminations. So the idea of removing heads up racing during final eliminations is ludicrous, unless we want to completely remove performance as a part of Stock and Super Stock. More often than not, class is NOT contested at National Events. Removing heads up races from final eliminations is a bad idea. It's the last thing that should be done.
Alan Roehrich 212A G/S |
Now you know why car counts are falling like a stone, the economy won't stop a diehard racer....knowing that there will be a couple hitters in your class at an event you want to enter will make you stay home...I have seen it a lot....heads up during eliminations HAS to go, it has no place now, NHRA wants to grow and it will if they look at the facts that speak for themselves....go run heads up at a heads up event, they are popping up everywhere, NHRA took on the dialing system years ago to "level the fields" and make policing the classes easier and the way it is now is not level....this would eliminate a lot of deep thinking about what to do with a combo....maybe I am looking at this backwards Alan, maybe they should eliminate the dialing and run everything heads up again....oh, that's right they used to do that and that is how we ended up with PROSTOCK
The economy WILL stop a diehard racer. No money = no racing. I know plenty of people who have been sitting it out over money. Car counts are down due to the economy. Even people I know who are behind when it comes to HP will go race when they can afford it. Right now, they can't afford it. I do not know a soul who has stayed home fearing a heads up run. If you're smart, with a little luck you can work the ladder to avoid a heads up.
No, we do not have to eliminate heads up runs in final eliminations. It's the last thing that should be done. And it will not help car count or spectator count. Heads up no breakout racing is one of the few things all fans do understand.
Liked 282 Times in 103 Posts
Not really. Before we got to where we ran decent, we learned to move around on the ladder to avoid heads up races. And we did not get a heads up race we did not want for a long time. Now we run pretty decent, and we do not worry so much about a heads up race. You can work the ladder. It is just another racing skill.
Liked 317 Times in 103 Posts
Alan, if they do not use incrementals, then the problem will never be corrected. There is no other way to guage a cars performance.
Additionally, how many racers that are trying to "save" their combo are set up slow at the 60' to 660". They're not, they cut back on the top end. So much for avoiding the free pass Ron Ortiz U/SA tick, tick, tick
Ron Ortiz 2102 STK |
#7 | |
Liked 7,770 Times in 1,741 Posts
Mark, believe it or not, I'm not concerned about U/SA. Go reread my comments from the beginning. I have used Bobs combo as an example as it is the most graphic and the most current. I also have never had a heads up run in eliminations and that's a lot of rounds.
Alan, I agree with cwigle about the more obscure combos in the more popular classes getting hit first. The more of a given combo, the more likely that combo is to have more proportionately slow and fast cars. The Hemis and 6 packs seem to have proven this. How about this, instant hit the cars off of the 1/8th mile indexes. It's simple and it won't affect any of the other triggers. For that matter, let's look at putting all of the triggers at the 1/8 mile. Also, I like Beardies idea about weight in the cars. If for example, a car enters a race classified as a AA/SA car and on it's first qualifying pass goes across the scales at A/SA weight (8.00-8.50) then give the driver the option of running A or taking the weight out of the car to make AA. On his second qualifying pass if he stays in AA and the car weighs more that 8.00 lbs then the driver is DQed for the race. Ron, as much as I like the CIC thing it won't work in Stock and SS.
#9 | |
If you have 2-3 cars running a combination that is capable of easily running 1.4 under, and and 25-30 cars running a combination that will run 1.2 under, the 25-30 cars will get hit first, and more often, because one slow car out of 2-3 is a bigger percentage and affects the average more than 5-6 slow cars in the 25-30 car group. If you move to the 1/8 mile index, you'll hit automatic cars harder because the stick cars ET better further down track than the automatic cars. You'd also have to look at the fact that quite possibly the cars running more than 1.4 under gain more in the second half than the cars running 1.2 under or less, so the difference at the 1/8 mile may not be great enough to hit the faster cars first and/or harder. I'd have to look harder at a lot more data to see if trying the trigger at the 1/8 mile mark could work. If you take away weight as a way to kill off ET, a smart racer will just kill timing and/or short shift to kill off ET, or do something else. We used to do it all the time running Super Comp instead of adding weight or using a throttle stop, because weight hurt the reaction time. Shift 1000RPM (or more) sooner for one or two shifts and you slow down. How are you going to stop that? Kill 20 degrees of timing and you slow down (all you have to do is leave the start timing retard on). How do you stop that? There are a bunch of ways to kill ET, too many for them to police. We can run the car 30 degrees hotter and kill ET. We can put thick oil in it, and add an extra quart and kill ET. Weight is just easy.
