Old 03-08-2009, 09:29 AM   #7
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Re: 12 bolt bearing cap
i found if you tap the existing threaded holes deeper with the 2nd of a three tap set (not the starter taper tap and not the bottoming tap) so that the tap end goes flush with the back side of the opening you can still bottom out a set of studs with over an inch of thread holding. even through the studs bottom out i still used blue locktite.
Ian
Ian Hill is offline   Reply With Quote
