Liked 428 Times in 116 Posts
Buy the Strange system, i agree with Tom, i have a 3500 lb Camaro, i ran it last season with Strange fronts only no problem, now i have dual strange on the rear. trust me i can hold it at 5000 on the foot brake now, without a problem, BUY STRANGE Brian
Thanks for all the replys guys!!!
So i am set on the Strange brakes!! Will be ordering next week. So i will be removing the stock distribution block that the car has now and installing a new strange adjustable prop. Valve. All the lines will be flushed but will remain the same, as will the stock 68 camaro master cyl. (master was new three years ago) I will also be buying the brake pressure gauge that screws into the bleeder. I was told that would help in adjusting the prop valve. He said to set them between 550-650lbs. and they should be fine. Thanks again and if anyone has any recomendations or tips or anything to add to that please let me know!! thanks -Scott Hakucsa- |
#3 | |
Liked 64 Times in 14 Posts
Scott I know you cut Lamb out of this picture But you should call Roger and ask him why his brake packages cost more He is a great guy to talk to and he will explain why After talking to him make up your own mind Many have bought brakes by others only to call him and end up with Roger fixing the problems And I have his brakes on both cars so I know what he is about... (909) 985-1901
Mark Callanan 1027 STK |
Banned
This is how "good" they look if you have "big windows" in the wheels!
Look n a little rusty
Tony Hall 3545 S/ST |
Liked 882 Times in 236 Posts
Looks like it's been driven on some of our fine highways here in the Northeast! ....Seriously,Ive never had more than a little surface oxidation in the rotors,but my cars are always in a heated shop, or an insulated trailer. .....Tom
Banned
Scott,
Take Mark's advice and call Roger. I have had all brands on different cars in the past. All had different problems! Lamb Disc Brakes are the only brakes to buy. The quality and service is second to none. |
