Old 02-28-2009, 01:15 PM   #1
Don Whitmore
Talking Re: 1960 283 chevy
A powerglide versus turbo 3-spd difference is not that easy to figure out. A pure back-to-back swap won't give you correct answer. You need to optimize each setup i.e., cam, gear, tires etc.
That said, I would guess an optimized turbo 3-spd would be better due to less converter slippage and ability of trans to keep engine in a more narrow power range. There are some on this board who have good knowledge of converter efficiency, would like to hear their input...
Don Whitmore is offline   Reply With Quote
Old 02-28-2009, 05:53 PM   #2
goinbroke2
Liked 393 Times in 153 Posts
Default Re: 1960 283 chevy
Bruce Fulper did a story a few years ago with regards to engine rpm and how quick an engine rev's etc.
It was with pontiac's (of course) but the gist of it was, a bigblock or long stroke/heavy rotating assembly engine rev's up slower than a lighter small block/short stroke/etc. A bigblock that prefers to spin up at 600rpm per second would be quicker with a glide due to less parasitic losses (spinning up the assembly) than a 3spd which would require 900 rpm per sec. A small block however that loves 900 rpm per sec would be slower (or at least not faster) with a glide because it doesn't have the reserve torque.
Veh weight the same, gearing the same, all else the same, a slow reving (reving up) big block is quicker using torque where a quick reving smallblock needs more gears/closer ratio.
More coming back to me...two 455's on a dyno, the newer one with an extra 20hp was actually slower because it was tested at 600rpm per sec and the gearing of the car and the old 455 was set up for 900rpm per sec. The new motor couldn't spin up as fast and was therefore slower on the track.
Speaking of Bruce..anybody heard from him lately? Reading some old BracketRacingUSA mags the other day and came across a couple other of his stories.
Old 02-28-2009, 08:20 PM   #3
Jeff Goss
Jeff Goss's Avatar
Unhappy Re: 1960 283 chevy
Get on the Pontiac Forums much? Some "questionable" business practices have hurt his reputation.
Too bad, as he was one of the "go to" guys when I started getting into Pontiacs about 20 years ago.
Jeff Goss is offline   Reply With Quote
Old 02-28-2009, 10:08 PM   #4
Bruce Fulper
Liked 54 Times in 33 Posts
Yeah, make sure you get your news from a bathroom wall, instead of talking LIKE a man, to a MAN.
I expected more out of you than THAT kind of gossip Jeff.
Bruce Fulper is offline   Reply With Quote
Old 02-28-2009, 10:58 PM   #5
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Cool Re: 1960 283 chevy
Did you ever settle up with Sal Piaccentini?
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 03-01-2009, 11:13 AM   #6
Jeff Goss
Jeff Goss's Avatar
Bathroom wall? Riiight. I think you made your own bed on this one. No doubt you are great with Pontiacs. That was never the issue.
Sorry you are offended. I just can't believe that ALL your naysayers are wrong. If they are, I sincerely apologize.
As to me being a man, I am a man that would always make good if someone I sold parts to or did work for wasn't satisfied. I am a man that stands behind what I say and do. I am honest to a fault, even if I have to take a loss to make someone happy. I put friendships first over my ego and wallet.
Sorry for derailing this thread.
Old 03-01-2009, 02:10 PM   #7
goinbroke2
Wow talk about stirring up a ****storm unintentionally!
No I've never been to a pontiac forum and I've never heard anything negative. I've read lots of his articles and he obviously knows hit stuff.
Speaking of which, Hi Bruce good to see your still around. Was my memory anywhere close to what your intent of said articles was or was I out in left field? LOL! I understand what you were saying, I'm just not sure if I put it as clearly as I could have.
Old 03-01-2009, 02:39 PM   #8
Jeff Goss
Jeff Goss's Avatar
We'll just leave it at that.
I got no dog in this fight.
Sorry Mr. Fulper.
