Old 02-23-2009, 01:01 PM   #1
Chris1529
Liked 70 Times in 29 Posts
Default Re: Adjustable front struts for Mustang who's to run?
My car is a GT 350. I had to put a ball joint on it last spring before I left for Mooresville.
I got one for an 84 GT and it did not fit. I went back and asked for one for an 84 SVO and it fit.
My car, being a 20th anniversary model, must have a conglomeration of parts, but the adjustable struts still did not fit.
Chris Alstons chassis works also makes a double adjustable strut for the fox body cars.
I have run lakewoods on my car for 10 years.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 02-23-2009, 04:00 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Santuff if you have more money than you know what to do with, or QA-1's if you want the most bang for the buck. Works on my car.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-23-2009, 11:27 PM   #3
west coast
Liked 223 Times in 73 Posts
Thanks everybody for the input. Still doing research don't have enough money for the Santuff or the Varistruts. The QA1 looks very good and shaves a few pounds off the front. Still have lots of work to do before the first race in May to the 90 Mustang. All ready aquired the Moroso front springs.
Wheels up everybody
west coast is offline   Reply With Quote
Old 02-24-2009, 05:28 PM   #4
Rory McNeil
Wheels up everybody
Let us know how you make out installing those Moroso front coils in your Mustang. I have a pair that I`d like to install in my car, but you can`t use a normal coil spring compressor on a FOX Mustang, and they are so long that I`ve never had any luck installing them by letting the lower control arms hang from the inner pivots. Anybody ever install these springs (uncut) in a FOX without using the factory type Ford spring compressor?
NHRA 6390 STK
M/S 85 Mustang
Old 02-24-2009, 11:03 PM   #5
west coast
Rory I have only done it with about 5/8 of a coil cut out on a freinds car it was still not easy. I am going to try uncut when I buy some struts. I will let you know how it goes.
Old 02-25-2009, 07:09 AM   #6
Chris1529
I have Eibach drag springs on my car. I made my own spring compressor, but it was very tough to get them in. I don't know how the Moroso's compare to the Eibachs.
Chris Bowman
1984 Mustang GT350
Old 02-25-2009, 04:30 PM   #7
87gt50
I'm not familiar with how the factory type Ford spring compressor looks like, but I have put in uncut Moroso dragsprings on my FOX using a compressor that I believe is designed to be universal, but also fits the Mercedes springs. Its a fine threaded rod that is inserted on ths inside of the spring, then put in removable brackets on the second coil top and bottom and compress until coil bind. (I usually secure the spring here with a strap to prevent it from being able to pop out at vany point.)
Raise the A-arm to "catch" the bottom of the spring, using a jack. When fully raised, start loosening the rod, and finally remove it through the hole in the A-arm located in the center of the spring seat and remove the brackets.
I found a picture (attached) of how this compressor looks like when in pieces. This is from a Swedish store, but I'm pretty sure you can find it in the US as well.
I hope this explanation is understandable and useful.
/Joakim, Sweden N/S 88 Mustang
Name:	spring compressor.jpg
87gt50 is offline   Reply With Quote
Old 02-26-2009, 12:45 AM   #8
Notch1320
Check out www.maximummotorsports.com
They sell a front spring install tool for $13.95 that is a big help in installing front springs.
Part # MMT-8
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
