#1 | |
It is such a common swap that Late Model Restoration even has a kit. http://www.latemodelrestoration.com/...1&comp=LRSeven |
Liked 70 Times in 29 Posts
My car is a GT 350. I had to put a ball joint on it last spring before I left for Mooresville.
I got one for an 84 GT and it did not fit. I went back and asked for one for an 84 SVO and it fit. My car, being a 20th anniversary model, must have a conglomeration of parts, but the adjustable struts still did not fit. Chris Alstons chassis works also makes a double adjustable strut for the fox body cars. I have run lakewoods on my car for 10 years.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 275 Times in 76 Posts
Santuff if you have more money than you know what to do with, or QA-1's if you want the most bang for the buck. Works on my car.
Sean
Liked 223 Times in 73 Posts
Thanks everybody for the input. Still doing research don't have enough money for the Santuff or the Varistruts. The QA1 looks very good and shaves a few pounds off the front. Still have lots of work to do before the first race in May to the 90 Mustang. All ready aquired the Moroso front springs.
Wheels up everybody |
#5 | |
Liked 1,104 Times in 302 Posts
Rory I have only done it with about 5/8 of a coil cut out on a freinds car it was still not easy. I am going to try uncut when I buy some struts. I will let you know how it goes.
I have Eibach drag springs on my car. I made my own spring compressor, but it was very tough to get them in. I don't know how the Moroso's compare to the Eibachs.
#8 | |
Raise the A-arm to "catch" the bottom of the spring, using a jack. When fully raised, start loosening the rod, and finally remove it through the hole in the A-arm located in the center of the spring seat and remove the brackets. I found a picture (attached) of how this compressor looks like when in pieces. This is from a Swedish store, but I'm pretty sure you can find it in the US as well. I hope this explanation is understandable and useful. /Joakim, Sweden N/S 88 Mustang |
Check out www.maximummotorsports.com
They sell a front spring install tool for $13.95 that is a big help in installing front springs. Part # MMT-8
Shawn Allsup K/S 718 |
