Old 02-09-2009, 08:48 PM   #1
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Default Re: Polyurethane Transmission Mount
Originally Posted by larrylomascolo View Post
Moroso advertises a solid trans mount for auto and stick application ,now can someone tell me the use of that part,i used a solid with a stick and have seen some solid with auto,,.if no one uses a solid why do they still sell it .?
I ran a solid mount for years with no problems. Like mentioned I don't think you could get away with it in a car that has any flex. My super-gas car ran both a C-6 and then a powerglide both with solid mounts and no troubles. Car had a stiff chassis with motor plate, mid mount and trans mount.
Old 02-09-2009, 08:59 PM   #2
mannymen
Liked 13 Times in 7 Posts
I agree with Mike Gray. I have owned two 2x3 chassis framed cars and have run steel motor/mid plates and SOLID trans mounts in both cars and have never cracked a case. The new/old SS'er back halve has a poly mount due to not having enough chassis stiffness.
N/A
mannymen is offline   Reply With Quote
