#11 |
Liked 54 Times in 18 Posts
Please define untouched
#12 |
Larry's heads... (I beleive) were untouched as in straight out of a stock car... with 150,000 miles!!! I am sure he will chime in, and clarify this, but "untouched", or fresh, either way, very impressive!!!.
Shawn Allsup K/S 718 |
#13 |
Liked 115 Times in 5 Posts
Years ago I ran 11.80s with the H.O. combo, but John Presing has been 11.50s at 113 mph using E7 heads. It's hard to compare NHRA and NMRA cars because NHRA cars get slicks and a better drivetrain, but NMRA cars (I believe) can use flat-top pistons and they can run with a much smaller combustion chamber. Either way it's impressive to run 11s with those heads, especially when there are lots of cars with aftermarket aluminum heads that don't run as well.
Evan
Evan Smith 1798 STK |
#14 |
Guys,
Thanks for the input here. I had no intention to compare my thrown together engine, just curious....for fun. specs: 150,000 miles from an 89 GT (sitting under the bench since '99) PB Blaster used as the rings were freed, to turn it over. Took a few days of soaking. E7 heads with plenty of carbon B-303 camshaft (retarded 4 degrees) Crane valve spring kit Cobra 1.7 roller rockers Edelbrock Performer RPM 575 cfm Demon Mac 1 5/8" headers air pan sealed to hood McLeod diaphragm clutch GF 5R Transmission, clutchless 3.19 low gear 4.86 gear in the 9 inch launched @ 6200 shifted @ 6000 crossing at 6200 (tongue hanging out) 3025 pounds 28X10.5 Tires 11.69 and 112 mph. This was a hurry up deal. We thought it would run 12.30 or so. Thanks, Larry Geddes |
#15 |
Liked 3 Times in 2 Posts
Larry: what gear were you running and what RPM did you go thrugh the traps at? I have been struggling to get mine to work right all year, and wandering what gear to use witht he new setup
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
#16 | |
Liked 165 Times in 54 Posts
NMRA F/S guys run a 58cc head, but none the less, the things they do with a stock combo, as awesome Evan I got every mag of your stocker buildup!!!! Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#17 |
Freddie,
4.86 gear 6200 rpm in the lights |
#18 |
Larry: thanks... are you still running the Kuntz motor? Car looked great in Chicago.
#19 |
Liked 70 Times in 29 Posts
Larry, have you tried the cam at different centerlines?
4 deg retarded seems alot to me for only running 6200 RPM. Do you use all 5 gears? Is 5th gear 1.1 ?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
