Liked 336 Times in 183 Posts
Have a chance to get the engine & trans out of a 91 suburban 78000 original miles body shot---Have not seen it do not know if its a 2 or 4 wheel drive vehicle 1/2 or 3/4 ton either---Lets assume it is a 1/2 and 2 wheel drive --it has a 350 inch engine with injection TBI right ???---Is the block a 2 or 4 bolt??---crank steel or cast??? is the injection set up worth anything-How about the heads???--Moving on to the trans is it a 350/400 or a 4L60 ??? All I really want is the shortblock is the other stuff worth anything or should I take a pass on it??? Probably will try to peddle it all off--- thanx Comp 387
Liked 99 Times in 60 Posts
The block could be two or four bolt, the only positive way to know is pull the pan. If it is four bolt, that is a desirable core worth about $175.00. The one piece seal blocks are fine, no reason not to run them.
Chances are, the crank is cast. However, that also is fine, no problem with running a cast crank. A stock cast crank is worth about $80.00 The heads have no special value except for a stock rebuild. Same for the throttle body injection. The trans will be a four speed, again, no special value except for a stock rebuild. The trans core is worth about $150.00
Larry Woodfin 471W |
Thank you for the info--Kinda what I thought no real value HI-
Perf wise ---Will look at other sources for parts trying to put together and mildly hop up a car/engine for my grandson---Comp387 |
