Liked 485 Times in 160 Posts
Some advice would be appreciated. My car will be using an alum front plate, .090 steel midplate and I have read in the TCI catalogue "never use a solid trans mount". Engine is BB Chev and trans is TH 400.
Chassis is round tube and car has certified (to 8.50) cage . |
That is good advice, NEVER. A sure way to break a case.
Ok , well I will stay away from the solid steel Moroso mount for sure. Thanks guys.
that's funny you started this thread. When we got my wifes 71 camaro bracket car it had one. took it off and just put on a stock rubber one. Was trying to sell the solid one, got tired of kicking it around the garage and threw it away on sunday.
Liked 1,987 Times in 599 Posts
Never had a problem with solid mounted trans. Solid mounted engine and solid mounted trans in my car. No issues.
Mike Pearson 2485 SS |
Motor plate. thin alum mid plate and a solid trans mount. never had a problem. In my car the cross member is non removable. You could probably pick the car up from the cross member as it is set through the tubes and welded inside and outside. not just butted up against and welded up
good luck |
I have always heard to never mount tail shaft solid...............but I have to tell you, I have no idea why. I would think that if everything is mounted as solid as a rock, but then you have the tail shaft just bouncing around, that would cause breakage. I am sure chassis flex has alot to do with it, anyway, i have had everything solid mounted on my car forever with no problem.
My car weighs 3330 lbs,turbo 400,pontiac engine front plate, mid plate,crossmember is round tube bolt in,tailshaft is bolted straight to the crossmember.2X3 Chassis 4 link a arm car.No issues in 8 years running 6.70 1/8 mile 10.70 1/4 mile 60 ft 1.38.If the car don't twist shouldn't have a problem.
We use the urethane mounts on every car built in the shop. With 1/4" front and mid-plates, or with the .090" mid-plates ( which I consider obsolete, 1/4" mid-plate helps to transfer torque to the chassis and the thin steel plates distort). Never had issues with breakage, However, the ones built with solid mounts at the least cracked the mounting bosses on the case even if the housing survived.
Mitch Perkins Perk-Bilt Race Cars DragCoverage.com Staff Photographer |
