Old 06-29-2008, 01:46 PM   #1
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
Default Parts for sale
Please see the below items. Reasonable offers accepted. All items do not include shipping.
Please help the Smith kids with their Junior Dragster endeavors
Email with questions
ssia1072@yahoo.com
Tools and Equipment
Powerhouse/Comp Cams, part #101215, pushrod length checker, 6.8-7.8, NEW in package $17
Powerhouse/Comp Cams, part #101220, pushrod length checker, 7.8-8.8, NEW in package $17
Drivetrain
TCI 7” converter 6400 flash (12 runs) $575
ATI 8” converter 6000 flash (FRESH 0 runs) $650
PG stock pan, with bolts, used $10
Pro King, trans filter, #FK-252, NEW in package, $3
AC trans gasket and filter, #TF-236, NEW in package, $3
Fram filter kit, for turbo 350, #FT-1033A, NEW in package, $3
Hurst, boot cover, used, in great condition, $7
Trans to crossmember mounts (3), rubber/steel, used, $5 each
Spicer, u-joint, # 5-160X, used, $5
PG dipstick tube and stick, used, $5
PG chrome dipstick tube only, used, $5
Flywheels, factory oem, sbc, 168 tooth, (4), used, $10 each
Flywheel, sbc, chrome, 168 tooth, used, $10
Flywheel, factory oem, sbc, 153 tooth, used, $10
GM throw-out bearing arm, used, $8
Tires/Wheels
M/T bias slicks, 13.5x31x15, used, $60
Wheel studs, steel, hexhead, 7/16”x3”, 5 only, used $10
Moroso, wheel studs, steel, 5/8”x4 ¼”, 10, steel shoulder lugnuts, short and long aluminum spacers, NEW $100
Aluminum lugnut spacers, 5/8” stud dia, 10 @ 1 ¼”, 10 @ 9/16”, NEW, $30
Summit part #G1495 wheel screws, gold iridite, (35), NEW in package, $10
Cragar center caps (4), covers lugnuts and center, 4 ¾ bolt pattern, used, $30
Weld center cap (1), used, $3
M/T tire/wheel cover, NEW, $5
Chassis/Frame components/Headers/Brackets
67-68 Camaro OEM front tie rod ends, used, $25
67-68 Camaro sbc OEM frame mounts, used, $20
67-68 Camaro, sbc solid motor mounts, used, $20
Merge collectors, 2” tube, 3 ¼ collector, 14 ¾ length, not coated, used, $150
Header flanges (2), for 3” collector, 3 bolt design, NEW, $5
Header flange plates, unk make, rounded top and square bottom, maybe Ford?, $3
Mr. Gasket, part #976, hex head header bolts, 5/16-18x3/4” 14 count, NEW in package $6
Mr. Gasket, part #917, hex head header bolts, 3/8-16x1” 12 count, NEW in package $7
Header bolts, 12 point head, 5/16-18x3/4”, NEW in package $6
Collector hardware, ½ set, NEW in package, $5
RCI, jr dragster restraints, (2 sets), expired $20 each
GM accelerator bracket, unk model, used $8
Alternator bracket, chrome, early sbc, used, $8
Carbs/Fuel/Pumps
Carb Shop, # 7058213 Q jet, race ready, $375
4GC carb cores, and various pumps, springs, etc with the following part #s:
7020633, 7028821 (2), 7020631, 7023006, 7028823,
4GC prepped carbs for racing: 7020631, 7032600, $250 each
2GC carb core, #7024110, $75
Q jet core top, part # 64601, $10
BG phenolic 1” 4 hole spacer $30
BG phenolic ½” 4 hole spacer $25
BG 400 pump, (1), remanufactured $275
BG part # 170036, O ring kit, NEW in package $6
BG part # 150889, #12 bulkhead fitting, NEW in package $20
BG part # 16009, steel carb bushings, NEW in package
BG part # 140013, #8 inlet, NEW in package,
Mallory 4 port regulator, remanufactured $65
Mr. Gasket, part # 3715, universal fuel line, NEW in package, $3
Mr. Gasket, part # 2072, inlet fuel bushing, NEW in package, (2),
Q-jet ¾”aluminum spacer, used, 3 available, $10 each
Fram fuel filter, part # FF-219, NEW in package, $3
Fuel jug lid with screen and spout, $5 SOLD
Fuel check valve, #8 fitting, used, $20
Gauges
Autometer, part # 3511, fuel tank gauge, 2 5/16” face, used, $10
VDO volt gauge, 1 ¾”, used, $15
VDO part # 153004, 0-30 mechanical pressure gauge, 1 ½” face, NEW in package, $20
SW fuel pressure gauge, 1-15 psi, 2 ¼” face, used, $10
SW water temp, mechanical with probe, 1 ¾” face, used, $10
SW oil pressure gauge, 1 ¾” face, used, $10
Cyberdyne part # A020E060N, digital water temp gauge, 1 ¾” face, NEW, $20
Pressure gauge, unknown brand, mechanical 0-60, 2 ¼” face, NEW in package, $15
Archer noise filters, for use with VDO tachs, (2), $10 for both
Ignition/Electrical/Switches
Crane Hi Fire part # 730-0092, PS 92 coil, NEW $65
Crane Hi Fire part # 730-0092, PS 92 coil, used $40
Crane Fireball ignition tester/tach calibrator, NEW $75
Crane part # 9000-1000, Hall Effect Crank Trigger, NEW in pkg, $125 SOLD
Powermaster starter, part #9400, for sbc, NEW in box $225
MSD part # 8980, spark timing control, used, $75
MSD style magnetic pick-up, 2 wire, (4) NEW in package $30 each
Powerhouse, part #102100, Innovate LM-1 basic kit, Oxygen sensor, NEW in package $300
G-tech performance, Pro accelerometer, NEW in package, $20
Moroso style external battery kill switch, used, $5
Performance Tech, part # W89720, infrared thermometer gun, used, $40
Shielded 3-wire cable, (2), NEW, various lengths,
Shielded 2-wire cable, NEW, various lengths
Engine Componets/Pistons/Rods/Shortblock
SBC 9 GM rods, polished beams, 7 Summit rods (5.7), 7 Ross/2 BME pistons (350 +060), used, $200
SBC steel deep oil pan w/ kick outs (used), w/timing chain/gears (new out of box), t/c cover, 2 oil pumps and spacer, $50
Chevy harmonic balancer/pulley combo for early sbc, used $25
Chevy harmonic balancers, BBC, large diameter, used, (2), $15 each
Chevy early sbc oil filter canister, used, $15
CP pins 875-2250-10CP35, (8), used $20
Imperial fanspacer, # 252008, 5/8”x2x5/8”, NEW in box, $5
Fan spacer, 3 1/8”x2”x5/8”, used, $5
Heads/Valvetrain/Intake components
Jesel, rockers, part # CABL/CABR, 1.8 ratio, set of 8, NEW in box, $450
Jesel, rocker, part #CLFR80, 1.8 ratio, .300 offset, NEW, $60
Jesel, rocker, part #CLFL80, 1.8 ratio, .300 offset, NEW, $60
Jesel, rocker, part #CAAS60, 1.6 ratio, no offset, dyno time only, $45
Jesel, screw cups, (5), NEW out of package $75 pack
Jesel, rocker bearing/trunions (5), NEW in package $15
Jesel, bearing/trunion snap lock rings (5), NEW $7
Comp Cams, part #4508, 7/16” adjuster nut, NEW in package, $10
Comp Cams, part #611-16, 11/32 super lock, hardened steel, NEW in package $17
Comp Cams, radial 11/32 lock, hardened steel, NEW in package $20
Comp Cams, valve springs, used (dyno) springs (12 sets), part # 086, 099, 350-400 lbs easily,
Comp Cams, used cam, 4482S/4496S R106 X4920, standard size, no swap, $80
Comp Cams, roller rocker arms (8), 1.6 ratio, machined for big springs, used, $75
Crane roller rocker arms (8), 1.6 ratio, machined for big springs, used, $75
SBC stock rocker arms, 24 total, with washers and nuts and 8 poly locks, $125
Powerhouse, part #102114, stainless steel bung/plug kit, NEW in package $6
Powerhouse, part #301090, spark plug index washers, NEW in package $10
Powerhouse, part #301020, 14mm air hold fitting, NEW in package $5
Mr. Gasket, part #5812, sbc intake gaskets, NEW in package $17
Mr. Gasket, part# 102 or 102G, sbc intake gaskets, NEW in package $8
Mr. Gasket, sbc intake gaskets, NEW out of pkg, 2 sets, $10
Mr. Gasket, part #106, sbc intake gaskets, NEW in package $10
Mr. Gasket, part # 5425, baffled grommets, fits 1 ¼ ID hole, NEW in package $5
Manley Valves, 8int/8exh, 1.50x5.100 and 1.94x5.150, 2 sets available, used, $100 per set
Manley Valves, 8 exhaust, 1.50x5.100, equal weight, NEW, $80
Manley, part #13161, hardened steel locks (16), 10 degree standard, NEW in package $25
Ferrea, part #K10053, 11/32 standard radial Titanium lock, 10 degree, NEW in package $100
Ferrea, part #E11016, Titanium retainers, 10 degree (16), NEW in package $300
CSR billet aluminum valve cover grommets, pair, NEW out of package $30
Misc set of 10 degree, 11/32 standard, valve locks, NEW out of package $10
PBM, sbc chrome valvecover, NEW in box, $25
Edelbrock Victor “E”, part #2978, NEW in box, $280
CSR part #530, index rings, NEW in package, $15
Miscellaneous
Federal Mogul, part #440972 rotor seals, (2), NEW in package, $10 for both
Oil-tite, synthetic drain plug gaskets, 5/8”, NEW in package, $3
Oil-tite, copper drain plug gaskets, 5/8”, NEW in package, $3
Waterpump spacers for SBC CSR waterpump, used, $10
Water jacket housings, chrome for sbc, 1 straight and 1 right angled, used, $5 for both
Valvecover holddowns, misc, 8 bronze anodized, 6 chrome, 1 blue anodized, used, $5 for all
Bondo fiberglass cloth, 8 sq ft per package, 8 packages, NEW, $10
Bondo liquid hardner, NEW, $2
Steering Wheel, used, $5
Chapin, 4 ft Industrial hose, NEW in package, $5
TS 115, 5” dual cone slimline speakers, (4), NEW in package, $10
Lubricants
Local pickup only
Valvoline, 5 gallon bucket 0-20 “qualifying oil”, NEW, $50
Valvoline, super coolant, quart size, 3, NEW, $5 each
VP Cooldown, pint, 2, NEW, $5
Geddex, burnout guard, pint size, $5 SOLD
Slick 50, engine oil treatment, quart size, NEW, $15
Valvoline, 75-90 synthetic gear oil, quart size, 10, NEW, $5 each
Thanks for the inquiries.
Ronnie Smith Jr is offline   Reply With Quote
Old 07-01-2008, 12:42 PM   #2
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Parts for sale
Ronnie ,I will take the 137 spark plugs .If you know anyone going to Pittsburg ,I can get them there. If not ,maybe you know someone going to Clay City .If you do you could get them to Hank in tech.Or just call me . /thanks
Old 08-13-2008, 08:34 AM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Parts for sale
Ronnie;
I am intrested in the Fuel jug lid with screen and spout, $5
Is it for the 5 gal race style jugs? are the threads for the spout in good shape?
If so I will take it and the Geddex, burnout guard, pint size, $5 what is shipping to N. Illinois. 60135?
Thanks
Bob
Old 08-15-2008, 05:57 PM   #4
Ronnie Smith Jr
Rallye
Sorry for the delay. I have been on vacation.
Yes, the fuel jug lid with spout fits on the traditional 5 gallon fuel jug.
Priority=$12.95
Flat rate=$9.80
Parcel=$8.37
Let me know.
ssia1072@yahoo.com
Thanks for looking.
Ronnie, Jr.
Old 08-16-2008, 05:44 PM   #5
Ellsworth Cheeks
i would like get the carb from you.
Ellsworth Cheeks is offline   Reply With Quote
Old 08-17-2008, 10:03 AM   #6
rallye bob
rallye bob's Avatar
Ronnie;
You have a PM......
Old 08-17-2008, 05:05 PM   #7
Ronnie Smith Jr
Bob,
Replied to your PM
Ellsworth,
You have a PM.
Old 08-17-2008, 10:59 PM   #8
Smitty
Smitty's Avatar
Ronnie,
What is the roll out on the tires you have (31x13.5x15) if you still have them? If you do have them what is UPS shipping to zipcode 33621?
Smitty
Smitty is offline   Reply With Quote
Old 08-18-2008, 11:33 AM   #9
Ronnie Smith Jr
Smitty,
Not sure of the roll out. I do not have any rims to mount them and I did not use these tires on my car. I replied to your PM. UPS is outrageaously expensive. The best idea is what we discussed on the PM.
Let me know. Good luck with the car. Hope your trans woes have been fixed.
Ronnie
