Old 06-20-2008, 05:45 PM   #1
Mike Voth
Mike Voth's Avatar
Liked 57 Times in 14 Posts
Default WANTED: 15x14x4.5 or 5 wheels
Looking for spare set of rear wheels for our car. Currently using very light-monocoques and would like to find good back-ups without buying new. Prefer as light as possible. 15x14 with 4.5 wheel spacing, but 5 inch spacing would work. Anyone have any they want to unload? Thanks.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Mike Voth is offline   Reply With Quote
Old 06-22-2008, 06:41 PM   #2
lareagle
Liked 27 Times in 13 Posts
Default Re: WANTED: 15x14x4.5 or 5 wheels
Hi Mike
I have a pair of Weld Draglite 14 wide 4.5 back space .Also have Goodyear D5 Compound about 3/4 of the depth mark . I run a GT/B stick car. I'll sell all for $400. If you want both
or wheels for $300.
Call 740 633 1333 Days
Call 740 782 1166 Evenings
Thanks
Larry Eagle
lareagle is offline   Reply With Quote
Old 06-22-2008, 10:35 PM   #3
Mike Voth
Mike Voth's Avatar
Hi Larry, I appreciate the reply. The only concern I have with the wheels is weight. We plan to do some tire testing between the D4A 1823's and the D6 2121's, and would like to know that there is not much variance in wheel weights. Do you know how heavy your Draglites are. When we bought our Monocoques, they were the lightest on the market. That was several years ago, however. Again, thanks.
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Old 06-25-2008, 10:38 PM   #4
lareagle
Mike
The weight on tires & wheels with D6 2121. 50lb.on bath room scales.
Thanks
Larry Eagle
Old 06-25-2008, 11:35 PM   #5
Mike Voth
Mike Voth's Avatar
Hi Larry. Goodyear lists their 2121's at 34.2 lbs. This would be 68.4 lbs. in just tires alone. That would only leave 16 lbs per wheel. Weld told me the Draglites were 22 lbs. each and that is unfortunately too heavy. Our Monocoques weight in at 12 lbs. I don't want to take the risk, sight unseen. I'm just going by what Bogart and Weld told me. It's hard to argue with them. Thanks for all your effort!
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
Old 06-26-2008, 02:51 AM   #6
G Schenck
Liked 81 Times in 35 Posts
Check out Jeff Gillette's add on insidecompracing.com
He has three sets. One set are 15x15 w/4.75bs Monocoques
Greg
G Schenck is offline   Reply With Quote
Old 06-26-2008, 07:48 PM   #7
Mike Voth
Mike Voth's Avatar
The D6 2121's aren't recommended for a 15 wide wheel. But thanks just the same, Greg!
Mike Voth
5189 GTN - 5188 GTO
Voth Racing
