Liked 16 Times in 11 Posts
Steel rod bbc street engine may see 6500rpm if the owner gets too happy some days.
How close have you ran this without tapping the head? I usually shoot for .040 but this could run a bit closer. Thank you |
Liked 1,987 Times in 599 Posts
I run my race engine at .036. There would be no noticeable difference at .040. There is a lot of variables to this question. Bearing clearance, rod type, wrist pin stiffness, piston weight, piston to wall clearance. All have an effect on deck clearance.
Mike Pearson 2485 SS |
In a street engine, I see no reason to
go any closer than 040. I run 050 due to the fact that I will get carbon build up over the miles of a street engine that I do not get on the race cars.
Liked 1,925 Times in 432 Posts
Easily runs at 0.042. Might get away with 0.038, but not worth it. You can buy a Cometic to get it exactly right.
Alan Roehrich 212A G/S |
