Liked 649 Times in 140 Posts
Obviously AI is thinking way outside the box here and way beyond what?s realistic but a couple of the comments have merit. The review panel including NHRA, engine builders, etc. the max limit on HP in a year, the graduated HO penalties. I just did this for fun so don?t go ballistic over the answer! I wish NHRA would simply leave the -1.30 penalty in effect everywhere with a 5 HP penalty for every hit and dump the rest of the system.
DeepSeek V3 Fixing the NHRA Automatic Horsepower Factoring System (AHFS) requires addressing its core issues?fairness, predictability, and transparency?while maintaining competitive parity. Here?s a structured approach: 1. Improve Transparency & Consistency Publish Clear Rules: Define exact parameters (e.g., weight breaks, RPM limits, performance thresholds) that trigger adjustments. Real-Time Data Access: Allow teams to monitor their AHFS adjustments in real-time via NHRA?s databases. Explain Adjustments: Provide detailed reports on why horsepower factors are altered (e.g., ?X engine combo gained 0.3% in ET, triggering a Y% HP increase?). 2. Refine the Performance Triggers Use Multiple Data Points: Instead of relying solely on elapsed times (ET), incorporate: 60-foot times (traction efficiency) Incremental splits (330ft, 660ft, 1000ft) Trap speed (consistency vs. peak power) Adjust for Conditions: Normalize data using weather station inputs (DA, humidity, track temp) to prevent unfair penalties due to optimal runs in rare conditions. 3. Implement Gradual, Predictable Adjustments Smaller Incremental Changes: Instead of large HP swings (e.g., +15 HP overnight), use smaller, phased adjustments (e.g., +5 HP per race if dominance continues). Cap Maximum Adjustments: Set a seasonal limit (e.g., no more than +20 HP total in a year). 4. Introduce a ?Grace Period? for New Combos Allow 3-5 Races before factoring begins, letting teams develop setups without immediate penalties. 5. Establish an Independent Review Panel Comprised of NHRA officials, engine builders, and racers to review contentious adjustments and suggest revisions. 6. Encourage Parity Without Stifling Innovation Reward Rule Stability: Freeze HP factors for combos that stay within a tight performance window (e.g., ?0.05 ET over 10 runs). Limit ?Gaming the System?: Penalize teams that intentionally sandbag (underperform in qualifying to avoid AHFS). 7. Improve Feedback Loop with Racers Quarterly Meetings: Let teams voice concerns and propose tweaks. Simulation Tools: Allow teams to model potential AHFS impacts before making setup changes. 8. Modernize Data Collection Mandate Telemetry for Top Teams: Use onboard sensors to validate power curves and detect hidden advantages. Conclusion The AHFS should be predictable yet adaptable, ensuring competition stays close without discouraging participation. By making the system more transparent, data-driven, and incremental, NHRA can restore racer confidence while keeping the racing field balanced. Would you like a deeper dive into any specific area (e.g., weather correction models, historical AHFS controversies)? Last edited by 4543; 07-26-2025 at 08:26 AM. |
Liked 7,925 Times in 1,760 Posts
[QUOTE=4543;714791]Obviously AI is thinking way outside the box here
I wish NHRA would simply leave the -1.30 penalty in effect everywhere with a 5 HP penalty Leaving the -1.30 penalty with a 5 hp hit won't work at all but I'm pretty sure that depending on the program, AI would probably figure that out on it's own. -1.30 and a 5 hp hit has a far different affect on a 500 hp Hemi than it does on a 100 hp Pinto.
#3 | |
Liked 534 Times in 143 Posts
[QUOTE=Billy Nees;714795]
Liked 735 Times in 386 Posts
Liked 506 Times in 248 Posts
AI...
The Great Regurgitator... GIGO... |
I don?t think the incremental times will ever be valid in a dial in type race where people are concerned about breaking out. I think the point about taking weather conditions into account is valid. The 5.25 penalty is too severe unless your goal is to take a car capable of winning class and taking it out of contention.
Liked 2,006 Times in 602 Posts
I think they should bring back ?mineshaft? again. That seemed to be a good thing when it was in place. Also I like the idea of the incremental hits on HP instead of a huge hit that kills a combo. If you run 1.30 under or quicker it should be automatic tear down. I agree with Perone that if you can run 1.30 under in bad air you need an Adjustment. There has to be some sort of system in place to control the parity. It doesn?t effect me unless someone that runs my combo gets a HP hit. My engine combo is already carrying a pretty good penalty. Unfortunately you can?t get reductions any more once the combo has been hit.
Mike Pearson 2485 SS |
Liked 408 Times in 35 Posts
"HAL tear that car down before you give the combo horsepower."
"I'm sorry Dave, I'm afraid I can't do that"
George Wright https://9500rpm.com |
#9 | |
Liked 362 Times in 105 Posts
I am old and I get it. I saw the movie when it first came out. Put a smile on my face. Rick Cates Canyon, TX |
Liked 217 Times in 93 Posts
-1.30 and a 5 hp hit has a far different affect on a 500 hp Hemi than it does on a 100 hp Pinto.[/QUOTE]
Is there a hint here Billy? I you jumping ship for a Pinto? Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
