Old 07-08-2025, 03:16 PM   #1
goinbroke2
Liked 405 Times in 158 Posts
Default Alternator choice?
Running a stock ford alternator an regulator etc and was wondering what people use for alternator sizes?
1 wire 140amp? (one wire seems simpler...)
regular ford 48amp?
A 140amp alternator would give me peace of mind but how much drag will various alts have? Once the batt is back full the drag should be minimal regardless of size no??
Jim Miller
103 U/SA
Old 07-08-2025, 07:35 PM   #2
Default Re: Alternator choice?
Powermaster 100 amp 1 wire. They;re even available adjustable for voltage output.
Old 07-09-2025, 07:36 AM   #3
Crisco
Liked 47 Times in 21 Posts
House of Payne makes really nice 12v @ 100 amp alternators in a Super Mini and an Ultra Mini.
https://whitehouseperformanceparts.c...2v-alternator/
Crisco is offline   Reply With Quote
Old 07-09-2025, 11:21 AM   #4
cordoba13
cordoba13's Avatar
Liked 12 Times in 7 Posts
napa full size Delco 1 wire 60 amp ? SW something, only about $60
cordoba13 is offline   Reply With Quote
Old 07-09-2025, 03:43 PM   #5
goinbroke2
Checking them out now. I'll get a 100+ amp one just so I won't have to worry between rounds!
Thanks, for the info guys!
Jim Miller
103 U/SA
Old 07-09-2025, 06:11 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I don't run an MSD in my race car which I guess is a big draw in amperage but I run a stock 1963 30 amp alternator in my race car with a small pulley on the damper and never have to charge between rounds and I run the electric water pump and fan between rounds to cool sometimes.
Old 07-10-2025, 12:12 AM   #7
Rory McNeil
Liked 1,112 Times in 304 Posts
Like Paul, I have found the factory equipment alternator more than adequate. On my 85 Mustang Stocker, as well as my 78 Fairmont bracket car, I used the factory alternator and external voltage regulator, Ford offered them in several different output ratings, I think the alternator that has been in my Fairmont for almost 40 years, is less than 50 amps. That said, I am also using a full sized conventional battery, with 500-600 CCA. My cars have much of the typical drag car stuff, like an electric water pump, electric fan, electric fuel pump (s), and a MSD ignition, although I run 6 series boxes, I believe the 7 series boxes take a fair bit more current to operate. Over the years, I have found that as long as I had the battery fully charged before the race weekend, with the full size battery and alternator, I can usually go thru a 2 or 3 day race weekend without having to fire up the generator and charging the battery between rounds. About the only time that I charge the battery, is if I am in a "hot lap" situation during later rounds, especially on a hot day, so that I have to run the fan and water pump a lot. Obviously, if your alternator is non functional, that wouldn`t work.
NHRA 6390 STK
M/S 85 Mustang
Old 07-10-2025, 11:46 AM   #8
Eman
Liked 133 Times in 76 Posts
How much amperage do you think you need? What gauge wire are you running from the alternator that can carry the amperage?
Old 07-10-2025, 12:37 PM   #9
cad
cad's Avatar
Liked 93 Times in 52 Posts
Ive spoken with Tuff Stuff Performance. Their CS130 alternator is exactly the same one that is re-sold by hop. They can be purchased from summit. I have had both, and currently running the Tuff Stuff branded alternator. 7500rpm and it puts out 14.1v at 1000 rpm...
I do use hop's starter which is fantastic.
Old 07-10-2025, 08:59 PM   #10
CMcAllister
Liked 927 Times in 263 Posts
Nice stuff? Paynes
Budget? Delcotron with a one wire kit. You can carry parts for it - diode trio and rectifier - and fix it at the track if it breaks.
