#31 |
The rule book is quite clear on this.
ALL 2008 and up cars are allowed a 9" and an NHRA approved suspension. The corporate transmission rule applies because the Supra is built in a joint venture with BMW. BMW has a history of running GM transmissions in their cars. Not one rule was changed to allow this car into the guide.
Daren Poole-Adams NHRA Stock/SS 2007 |
#32 | |
Liked 101 Times in 52 Posts
#33 |
Liked 503 Times in 131 Posts
This is interesting, I'd like it better with a stick, but I'm sure the automatic will make it more driveable for most. I'd fit in it. Key is a close fit cage, done with care. Factory ECU or aftermarket, I use VF tuner for my street/strip toyota trucks. What Chassis shop is doing the build?
Eric
Eric Merryfield 1883 STK |
#34 |
Liked 10,963 Times in 2,260 Posts
It could use a mail truck transmission.
#35 |
Liked 230 Times in 75 Posts
This has gone to 7 degrees of Kevin Bacon or should I say 7 degrees of GM. NHRA new slogan should be SHOW ME THE MONEY. Just fallow the money. The history of nhra was built on providing a safe place to race and done safely but now they rarely even check the minimum of any safety device, let alone following there own rulebook that is not safety related items. What is the point of the rule book anymore, run what you brung.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#36 | |
Liked 1,032 Times in 283 Posts
Duane Hoven 1342 SS/GT |
#37 |
Same 7 degrees of gm. Jaguars used th400 in the 70s early 80s at one point ford own Jaguar. But they also own Cummins at one time also, turbos for all Fords with no hp rating change
#38 |
Do any of you remember the thread that I started on AMC transmissions a while back...
#39 | |
The 5L50 and 5L40-E BMW transmissions were manufactured by GM. |
#40 | |
Emissions compliant ? Cat-cons? EGR or latest technology? CAFE numbers? How many thousand miles of warrantee? Financing? Trade ins? Dying to hear ;-)
