#101 |
Liked 265 Times in 69 Posts
Been pushing buttons in my Max Wedge since the 70's . Wouldn't have it any other way.
John Dinkel 3295 STK |
#102 |
Liked 499 Times in 236 Posts
What differences are there between using a air shifter or not using one ?
Jake Biermann |
#103 |
Didn't know you don't run a 2 step !
Jake Biermann |
#104 |
Liked 1,363 Times in 368 Posts
sure don't. That's just one more thing that can't go wrong in my operation.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#105 |
Liked 127 Times in 61 Posts
#106 |
Liked 148 Times in 54 Posts
#107 |
#108 |
Liked 373 Times in 131 Posts
That's a big NO for me in Stock Eliminator
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#109 |
Liked 231 Times in 54 Posts
What a time we live in where how you shift your automatic transmission becomes such an emotional trigger.
Seems simple run a stick if you want to shift every gear yourself. Run automatic if you want the option to do it either way. I could care less on how my opponent does it. Blocking, shifting or stripe takers still won?t help racers who struggle. I?d prefer every one of my opponents have an air bottle. It?s one more thing that can go wrong with there run. Stripe takers will lose more runs then they will help with. Blocking is a great tool but you better be able to switch back when it gets dark. I understand the purity aspect of Stock Eliminator but her virginity was lost when we started allowing aftermarket components. I?m not the brightest bulb but I?m pretty sure edlebrock heads never came from the factory. Same could be said for Caltracs, afco shocks. Now that I pissed off everyone here let?s just realize there is nothing stock about what we do now and join together and support any group that tries to give us a place to compete. Instead of hassling and bitching about every detail.
Brian Anderson 5058 B/SA 99 Chevy Camaro SS |
#110 |
Liked 508 Times in 92 Posts
So you start out with an automatic transmission, then you turn it into a manual transmission. Now you want an automatic shifter, why not just turn it back to an automatic, shifting problems are solved. You don't need to move that lever to change gears anylonger.
Casey Miles 248H E/S |
