#11 |
Liked 11,000 Times in 2,263 Posts
It will be good to see another kool car at the track. Good luck.
#12 |
Liked 1,361 Times in 416 Posts
Tom Auger runs a 63 Dodge 330 two door with a 383 4bbl. His runs H/SA
https://garagehotrods.com/2019/04/26...-63-dodge-330/ Paul H |
#13 |
Liked 432 Times in 214 Posts
Mark, has that one got the horizontal pushbutton shifter on the left? If so you will love those buttons. Fingers curled under the buttons shift with the thumb push down lightly and squeeze the trigger that last 1/8th inch. Just remember though if you go with a reverse manual valve body 2nd gear freewheels...get good brakes on the car!
Do not be a victim of the death spiral of a transmission you cannot use to actually downshift in a car that is also very heavy and has inertia. And get a double master cylinder in it no matter what. Cool car though...you'll love it!
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#14 | |
Liked 327 Times in 121 Posts
