Old 04-19-2025, 10:02 AM   #1
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Default Unlimited
I wonder what the ET record would be if they didn't slow down the fuel cars with gear reductions, limitations, blower drives, etc. If someone would build a track that could handle the high speeds with a long shutdown area. I'm talking about no limitations or restrictions.
I remember the nitrous oxide cars were going over 300 back in the '90's I believe, before they got outlawed.
Put up a purse of say 1 million to see who is the quickest.
Surely they would be in the high 2's.
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 04-19-2025, 01:06 PM   #2
nhramnl
Liked 358 Times in 83 Posts
Default Re: Unlimited
I did some quick calculations, and if all restrictions currently in place were removed, Top Fuel cars could cross the finish line before they left the starting line.
Old 04-19-2025, 02:29 PM   #3
340Cuda
Liked 800 Times in 337 Posts
I don't think the tires are up to much more than they can run now on good tracks in good weather.
I am not sure better tires would be available even if somebody funded the project.
Old 04-19-2025, 05:29 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,174 Times in 971 Posts
I have a little different take...if they had adopted some of Big's recommendations (for example, must be able to restart the motor after the run or you're dq'd) then you would not need mega sponsors and you'd have large fields fighting for spots and you'd still be running 1320. Fans wouldn't know the difference, not as many aborted runs either. Scott, Blaine and others would still be out there too.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-21-2025, 06:02 AM   #5
Fred Elsass
Liked 300 Times in 42 Posts
Just put a turbo on it.
Sarge
Fred Elsass is online now   Reply With Quote
