Liked 5 Times in 5 Posts
Make reasonable offer for anything.
2 New World Products SB Chevy Motown 2 blocks # 084010 std. cam 842 lifter bore 3.995 cyl. bore 350 main nodular main caps $3300.00 each TCI SBC/BBC lightweight 29.2 168T flexplate PN 399870LW, like new. Weighs 6.09lbs. Can barely see the contact patch on the starter ring. Original date was 1/19, but was only ran in the car for 2 races. Will need recertified. Excellent condition $300.00 Jesel Dogbone lifters LFD-44002 .842 Diameter set of 16 $600.00 LS Bryant crankshaft 4" stroke 58x - $2600 Carillo rods 6.1 rods (was used with Bryant crankshaft above) BE :2.2253 PE :0.9285 Length: 6.100 B Width : 0.938 $1000.00 Oliver I beam 5.7 rods set of 8 BE: 2.125 PE: 928 Length: 5.7 Weight each: 575 Grams $500.00 Winberg SBC crank condition: NEW stroke: 3.496 main size: 283 chevy 2.300 rod size: 1.850 rod journal width: 1.800 bob wt.:1540 $3500 8 ATI converter - Flashed 6500 behind 427/430 LS Combo Powerglide spline - $500 7" Converter - Dynamic. Powerglide input, flashed 7000 behind 327/275 hp combo. - $500.00 Wilson 4 hole aluminum tapered spacer. Dominator flange PN 024110 - $150 used for test only Manley 221443P-16 valve springs with 23648-16 Ti - retainers, locks and 42573-16 locators (run on dyno) $200 for set. ATI balancer pulley PN 916794 4 groove aluminum 6.430 diameter - New $40.00 ATI balancer pulley PN 916732 4 groove aluminum 6.430 diameter used $50.00 CV products 3/8 pushrods (qty 18) 9.200 x .080 x 5/16 ends used but good condition $30.00 Trend 3/8 pushrods (qty 16) 7.450 x .135 x 5/16 ends used but good condition) $50 Trend 7/16 tapered pushrods (qty 16) 9.400 x .165 x 5/16 ends new - $150 Trend 3/8 pushrods (qty 8) 9.400 x .135 x 5/16 ends used - $25 Trend 3/8 pushrods (qty 8) 9.450 x .135 x 5/16 ends used - $25 Trend (qty 17) 9.150 DBL taper .135 wall pushrods 5/16 ends (used good) $35 Trend 9.400 DBL taper .135 wall pushrods 5/16 ends (11) new $150 Trend 9.300 DBL taper .135 wall pushrods 5/16 ends (11) new $150 JRI 2010-2015 Camaro front struts $500.00 used. Lingenfelter billet steel LS block girdle, No hardware $500 2 GM truck oil pans (1999-2006) pan only $50.00 each superstock@live.com for any questions or pictures shipping available for most all items. Paypal, check, or cash in person
Jeff Myers SS3254 S1522 Last edited by JeffM; 11-12-2024 at 10:03 AM. |
