Old 10-14-2024, 01:02 PM   #81
Default Re: It's About Time (Not MPH)
Someone asked about the trans axle R&R on my Escort , which is for sale down below.
I've only done it with it attached to the engine , which was easy enough. It's never had to come out for any reason. I'm pretty sure it will come out from the bottom, if one refers to a shop manual.
Also someone asked about the PCV system. You can see the factory tube that the valve sits in, in this pic. It's all a factory setup ,except that the breather hose and filter used to be in the air filter container , which is no longer used. It's now off the valve cover with a short piece of hose.
Old 11-29-2024, 01:11 AM   #82
Chuck Weissberg
Liked 57 Times in 27 Posts
Your mind is AMAZING...DR McGIVER
Chuck Weissberg is offline   Reply With Quote
Old 12-07-2024, 04:50 PM   #83
Chuck Weissberg
Almost time for smoke in the pipes...
nice job on the headers
