Liked 105 Times in 38 Posts
As the title says, what does a racer selling a stocker refer to when he mentions "Bracket Mode". Thanks in advance
Liked 129 Times in 51 Posts
That it's not on kill and should have more left in it.
Bobby Lundholm 3516 G/SA |
Liked 228 Times in 98 Posts
In the mode that it is normally raced.
Typical fluid levels and viscosity, regular water temperature, starting line RPM, etc.
Tony Leonard S/ST 56 S/C 53 |
Liked 8,244 Times in 1,541 Posts
Liked 5 Times in 4 Posts
Thanks guys!
Minimum weight, minimum amount of oil in the pan, air pressure as high as possible in the tires and as cold as you get the water temperature and Jim Marshall would never do this but ice down the intake.
Liked 88 Times in 43 Posts
![]() Couldn't resist. That's where you put in less, lighter oil, chill the engine, adjust the starting RPM line up, maybe some timing. Remove any extra ballast..... And the car picks up less than just removing the weight would... Last edited by Tom Broome; 09-13-2024 at 06:36 PM. Reason: accuracy |
