#11 |
Liked 75 Times in 28 Posts
#12 |
Liked 8 Times in 3 Posts
I build my own headers; I use a program called pipemax to design them for size and length. the program also can be used to build step headers. To answer your question when building a set to fit in an engine compartment and maintain equal length is pretty hard. Getting access for plugs and starter is just as important. On a dyno not sure what the loss would be on different lengths, but I seldom see any factory-built headers that are even close. I am a big believer in step headers and have seen gains on the dyno.
#13 | |
Liked 172 Times in 46 Posts
Dirk Olson 5036 STK |
#14 |
Liked 2,795 Times in 983 Posts
Kromer Kraft Headers
#15 |
Liked 103 Times in 25 Posts
Call Mike Schaefer at The Mod Shop - Lakeview, OH
He builds some awesome headers. He built the headers on Doug Duell's stocker and his SS challenger for reference. 937-935-9898 He has done a lot of work for me in the past. Great guy to work with. Casey FJ |
#16 |
Liked 73 Times in 37 Posts
Does equal length mean equal flow and pulse timing?
Seen a championship Pro Stock with unequal length primaries |
#17 |
Liked 759 Times in 379 Posts
equal length in our cars, cars with the firewall in the stock location, stock frame rails, etc. means sacrificing fit, ease of installation, spark plug access, ground clearance and in some cars, having to remove and or cutting the inner fender wells all for nothing on the time slip.
#18 |
Liked 70 Times in 23 Posts
I just went through this in my Cavalier. I ended up with equal length and in firing order. There was no way I could get the length I thought it needed with the tight space. So I had him put the proper collector length collector and connect the flange.
I will say this. Equal length tubes with a LS firing order (SBC), makes a crazy looking header. Have pics if interested. |
#19 | |
Liked 226 Times in 76 Posts
Andy Friar |
#20 |
