#81 |
Liked 405 Times in 158 Posts
I only have .382/.398 for lift and 30* is better for flow at low lifts. If i had a lot of lift then id use a higher angle like 60*. The 45* is the factory number and works like factory ?middle of the road?, same as factory cams etc.
Of course i know squat compared to any of the builders on here so maybe they will chime in??
Jim Miller 103 U/SA |
#82 | |
Liked 977 Times in 312 Posts
#83 | |
Liked 5,153 Times in 1,967 Posts
You've got the right cam and carb there. This is an easy combo. Don't try to re-invent the wheel. I don't see a flow bench in the the pics, so, in absence of one , you might want to use a 30, 45 sealing angle, 60, 70 and so on,...whatever fits ;-)
#84 |
Thanks mark, i was going according to someone else who ran the combo,(very successfully , lol) after grinding a couple practice seats on a garbage head im concerned about the valve drop. 30* was what someone else ran but that was after replacing all the seats. Dont think im there yet, 16 seats for a bit more power?
Im going back out and make a decision.
#85 |
I have two seats at 30* and im not a fan. So, either get the 45 back or ill have to replace the seats.
I did two others at my regular 15/30/45 seat/60 throat. I thought I had a 75 but i cant find it. Regardless, i like it better and if i lose a bit of power, im ok with that. I can see why "stock" heads can cost so much! Course if i was better it would be quicker but ive aready got about 17hrs into them with cleaning, guides, porting, (just kidding) lol! Still have to do the valve job and adjust stem height and installed height.. lots of hours left. I also got one side of the heat crossover in the intake plugged and need to do the other side, little by little, lol. And thanks to those who pm'd me!!
Jim Miller 103 U/SA Last edited by goinbroke2; 05-29-2024 at 10:27 PM. |
#86 |
Earlier tonight, only 11:30 pm, lol.
I didn't like how low the 30* seat was so I tried to save it and did! So I got all intakes and exh valves ground and the valve job done. 15/30/45seat/60throat After that was done I used lite springs to check stem height. Got them all within .012 by trimming the tip. Now I have to work on the installed height. Of course nothing is easy, the LED light on my valve grinder went bad and it's continually flashing, try to see where the contact is with that! LOL! After the heads were cleaned I see this mess in one chamber, not sure if someone chattered a stone or something let go, who knows but how do I fix it or can I fix it since you can't do anything in the chamber? Still moving forward, so that's good.
#87 | |
#88 |
What angle are you referring to ?
#89 | |
Liked 7,912 Times in 1,755 Posts
OH YEAH, it has to LOOK "Stock". ;-) Well ya know? I just re-read the rule book any YOU are correct! You are however allowed to CNC port the intake/exhaust runners and the combustion chambers! If you're running a FS car. Now that hardly seems "fair"!
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 05-30-2024 at 12:48 PM. |
#90 |
4th sentence says “must retain stock diameter and angle + - 1*”. But the 4th sentence from the bottom says “any valve job accepted”?
Well i did 4 angles (cant find my 75* ) 15 in the chamber, 30 below that, 45 seat and 60* in the throat. Im pulling my hair out because the flash and casting crap as well as the lip left from the 15 cut is killing flow but i cant legally remove it. Stock casting SUCK!! Lol! So much easier to make power when you blend, lol.
Jim Miller 103 U/SA Last edited by goinbroke2; 05-30-2024 at 05:10 PM. |
