Liked 288 Times in 90 Posts
289 Mercury 223 hp combo, Bob Fasio Autolite 4100 1.12, Coan convertor just freshened UCC 7", Motor has 20 passes since freshened by Jimmy Bridges originally built by Jim Kuntz, AFR aluminum heads with hollow stem valves Ferrera, Jesel rockers, Comp cam, Super Victor Edelbrock, SVO 4 bolt block, 4.065 bore, roller cam bearings, Schumann oil pump, Canton oil pan, 9" aluminum 3d member, 35 spline Moser rifle drilled axles with profile ends, 35 spline spool, 5.29 R&P, Turbo Action shifter, 2.92 low gear rollerized C4, trans cooler, Trans blanket, Goodyear 9x30 rear and Goodyear 28' front runners, Weld wheels, Kirkey seat, Roll bar with swing out, 5 gallon aluminum fuel cell, TeamZ subframe connectors, TeamZ anti rollbar, and rear upper and lower control arms, QA1 coil overs rear, Strange front struts, O2 shifter with Digital Delay control, most of items are less than a year old. Car is nice no rust, new carpet throughout. PM me for contact number and more info and pic's.
Serious inquires please. Ran .92 under 10.277/130.20 Belle Rose Div 4 points race and 10.445/127.50 Thunder Valley Div 4 points race. Car is available in Jun 2024 after Dallas Double. Have original build sheet from Kuntz& Co. $29,500.00 Thanks RJ Last edited by RJ Sledge; 04-30-2024 at 09:29 AM. |
Liked 880 Times in 311 Posts
RJ
I have one of my customers that is interested. Are there any pictures on line? First thing he ask me was" Will He Wheel & Deal" LOL Can you E-mail me some more info about the engine build (Build Sheet)? Old Friend I hate to see you sell. No telling how many "Free" hours I have put in on this ride...Glad to see the Fairlane come back... I really like that car. Adger
Adger Smith (Former SS) |
Adger
Everything is negotiable, and I appreciate any offer, need to start somewhere. I am trying to figure out how to add pictures and my computer skills are lacking. You can give him my number. Two one zero-373-4zerozero4 Thanks RJ |
Liked 5 Times in 3 Posts
So,
I may be wrong, but isn't the Comet hp @ 220 for the Auto? The manual is @ 223 ![]()
[SIGPIC][/SIGPIC] SS/MA 2890 Anderson & Toren Comet |
Liked 3,165 Times in 969 Posts
Both auto and manual are rated 223 in GT classes.
What is it with aluminum heads then?
230?? ![]()
210/220/230 hp (Automatic) Factory rating, NHRA rating and aftermarket head rating, 2930 lbs @ 230 hp
Normally run 3000 lbs Crossing @ 8100 rpm Last edited by RJ Sledge; 04-30-2024 at 12:18 AM. Reason: Hp ratings |
Sold pending payment
Thanks Class Racer RJ |
